5.7 idle fuel consumption per hour?
Discussion in '2.5 Gen Tundras (2014-2021)' started by mountainpete, Feb 9, 2022.
  1. Feb 9, 2022 at 3:03 PM
    mountainpete
    mountainpete [OP] Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Does anyone know the idle fuel consumption per hour of a 5.7?
    Use case:
    Snowstorm, tornado or mudslide. You're stuck on the highway inside your Tundra and you run the engine to keep warm and listen to the radio. Or you get stuck on the trail in a storm and the only thing you can do is sit and wait.
    Yes, the cats can get super hot and burn out with excessive idling, but it's better than freezing people.
    I have seen some napkin math online (sorry, it's in liters):
    Engine displacement in L * 0.6 = fuel consumption per hour
    That would mean a 5.7 would use 3.42 L per hour.
    So a 130L tank, assuming you get stuck when it is completely full, would last 38 hours of idling.
    Question: Does anyone have a more accurate fuel consumption per hour?
  2. Feb 9, 2022 at 3:08 PM
    xc_tc
    xc_tc New Member
    If anyone can measure the mass airflow at idle you can calculate the fuel consumption but it’s rough. You need to consider the increased idle speed for heater and other accessories.
    fuel (kg/hr) = MAF (g/sec) * 3.6/14.7
  3. Feb 9, 2022 at 3:08 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
  4. Feb 9, 2022 at 3:12 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    My scanguage says .44gph at idle
    .8 with a/c on
  5. Feb 9, 2022 at 3:12 PM
    AZBoatHauler
    So.Arizona
    I’ve seen scangauge data indicating about .5-.6 gph.
  6. Feb 9, 2022 at 3:14 PM
    mountainpete
    Is ScanGauge data for instant fuel generally accurate? I know it wasn't on my old Taco.
    Jeff_5_7 likes this.
  7. Feb 9, 2022 at 3:15 PM
    mountainpete
    That's a pretty sizable difference in an emergency situation.
  8. Feb 9, 2022 at 3:15 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Dunno
    it’s accurate when it tells me how much fuel I’ve used before I fillup
  9. Feb 9, 2022 at 3:21 PM
    xc_tc
    xc_tc New Member
    I checked some old logger data I have and was seeing around 7.8 g/sec which means 1.91 kg/hr. That equates to roughly 0.4 gal/hr. This was at 1500 ft elevation.
    mountainpete[OP] likes this.
  10. Feb 9, 2022 at 3:30 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    You'd be halfway to your answer if you turned your truck on when you started this thread
  11. Feb 9, 2022 at 3:37 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    My ‘06 sequoia idled at .38 gph
    i remember because i thought that was a lot.
    I miss that ride.
  12. Feb 9, 2022 at 4:20 PM
    2mchfun
    Start the truck and get sort of warm, charge the battery, turn off for 40 minutes, repeat. Hunger might get to you more than the gas issue!
  13. Feb 9, 2022 at 5:33 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    I measured it directly from the injector on my 2007 5.7 Tundra. Read the data directly off the CANbus. Mine was burning 1.6 gallons per hour at idle.
    I never played around with turning the AC off ect but I can.
    I only logged about a minute worth of data (1900 ish samples) on startup. It was a 60 ish degree day in Texas. Avg. was 1660 micro liters per second which is about 1.6 gallons per hour.
    At 70 Mph I Avg 4.75 gallons per hour burn rate so Avg Mpg of 14.7
    https://www.tundras.com/threads/a-d...fuel-use-from-data-logger-instant-mpg.101602/
    Reading some of these other post make me thinking my number could be a little high. I know it’s accurate however as this is the exact signal coming from the engine ECU. Might try again with the truck fully warmed up and AC off ect. People saying only .4 gallons per hour sounds kinda low for the 5.7 V8
    mountainpete[OP] and 14burrito like this.
  14. Feb 9, 2022 at 6:23 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Holy crap I hope that’s off.
  15. Feb 9, 2022 at 6:27 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    It's as direct as a measurement you gonna get lol
    Obviously a lot plays into factor here:
    Cold vs warm ECT
    Cold vs warm amb temp
    Engine load via consumer draw
    Etc
  16. Feb 9, 2022 at 6:30 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    There’s always the chance the equipment or reading is off…. He says hopefully.
  17. Feb 9, 2022 at 6:39 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Where did he hopefully?
    * reread it - He also did a cold start which I believe pulses injectors numerous times per cycle to help speed up catalyst heating.
    ZappBrannigan[QUOTED] likes this.
  18. Feb 9, 2022 at 6:44 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    “He says hopefully” meaning, “I hope”
  19. Feb 9, 2022 at 6:46 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    I know what YOU said, I dont see where HE said hopefully.
  20. Feb 9, 2022 at 6:55 PM
    mountainpete
    This is why I love this site. Great data points and considerably more than my napkin math.
  21. Feb 9, 2022 at 7:08 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I spent most of my money on women, alcohol and motorcycles. The rest I just wasted on idling my Tundra.
  22. Feb 9, 2022 at 7:35 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Looking into this more now. There is always a chance I missed a unit or scale factor and the data could be off. This is the first time I have thought to look real deeply at it.
    So far in my experience the data has always lined up well and made sense but I could have an error.
    14burrito likes this.
  23. Feb 9, 2022 at 7:37 PM
    2WD
    2WD New Member
    21 Army Green CM SR5 TRD Off Road
    What a great idea to figure this out. I remember a ford ad from a while back with Mike Rowe where they did an MPG test and to visualize the gas used, they had these small transparent gas tanks mounted to the fuel fills riding outside each truck to track usage visually. Like a kitchen measuring cup.
  24. Feb 9, 2022 at 7:56 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Few different tests would be good, few different and a few of the "same".
    I'm pretty sure the injector duty cycle on cold starts is two or three per to aid in cat heating.
  25. Feb 9, 2022 at 8:05 PM
    xc_tc
    xc_tc New Member
    Could be a factor of 4 based on everyone else’s reply of 0.4~0.5 gal/hr.
  26. Feb 9, 2022 at 8:11 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2 or 3%?
    I just did some quick math researching that stock injectors flow 370 ish CC/min at 100% duty. That’s 5.8 gallons per hour for each injector at 100%, 47 gallons total per hour (100%)
    If idle is 3% duty cycle I think that would be 1.4 ish gal/hr total
    If this math is correct to get to a 0.5 gal/hr at idle the injector duty cycle would only be 1%
    ZappBrannigan likes this.
  27. Feb 9, 2022 at 8:53 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    I heard from a trucker that his rig burned about a gallon an hour idling with the a/c on.
  28. Feb 10, 2022 at 3:33 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I pondered this....it only reads OBD data.
    I don't know how it could be inaccurate?
    side note...I accelerated @ 22GPH on the on ramp.....so there's that.
  29. Feb 10, 2022 at 3:38 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    for the math folks...
    this is at idle after a 25 mile drive, in park, no a/c...waiting for 5 dim-wits to figure out how to open a locked gate.
    if you remove a metric-smidge for the blower drag...you could be just under .5 GPH
    I attempted to put all the variables on the screen...IGN was a bonus.
    also...on cold start up....1.6GPH.
    mountainpete[OP] and batman900 like this.
  30. Feb 10, 2022 at 3:45 AM
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    I don't know but...when I had my '15 I got stuck going home from work in an ice storm, the drive was around 30 miles and took me about 8 hours. I'm guessing my top speed was around 35 MPH mainly in 2 WD with a lot of idling and going no where, I don't know if I ever shut it off. I started out with just under a half tank so around 12 gallons and had right at a 1/4 tank left. You do the math because I'm old, cranky, and don't give a rat's butt.
    nobodyintexas likes this.
