5.7 engine failure
Discussion in '2nd Gen Tundras (2007-2013)' started by rocketdog, Aug 18, 2025.
  1. Aug 18, 2025 at 1:04 PM
    rocketdog
    rocketdog [OP] New Member
    New member looking for advice. I have a 2013 Tundra 5.7 with 115000 miles. Well taken care of up to date on all maintenance. Driving at 65 mph the engine started running very rough as if I was going over a rumble strip in the road.
    Limped it to a Toyota dealer where they started with spark plug replacement. Diagnosed it as miss fire on 6 of the 8 cylinders. $500 No change. Next, replaced engine wire harness, $4500 No change. They recommend an engine replacement at $25000.
    My truck is now at an independent shop awaiting a diagnosis from them.
    The truck starts but seems to be running on 2 or 3 cylinders, very rough as expected, does at idle. Catastrophic engine failure? Cam shafts kaput? Anyone else have similar experience? Thoughts?
  2. Aug 18, 2025 at 1:24 PM
    jdg1982
    jdg1982 New Member
    Florence, Colorado (From Louisiana)
    2017 Magnetic Gray Tundra SR5 4x4
    $25,000 for a new engine? WOW! I'd just go buy a new truck at that point.
    I'm curious to see what the independent shops says.
  3. Aug 18, 2025 at 1:27 PM
    AZBoatHauler
    So.Arizona
    Sounds like a blown head gasket on that bank. When was the coolant changed last?
    if they would have borescoped it initially, it's likely they would have seen a steam cleaned cylinder or two. I'd want my $4,500 back for the harness you didn't need.
    woods, Bowzer, Mater and 11 others like this.
  4. Aug 18, 2025 at 1:55 PM
    rocketdog
    Coolant changed about a year ago, could understand it during winter months, this just happened a few weeks ago.
  5. Aug 18, 2025 at 1:57 PM
    AZBoatHauler
    So.Arizona
    You could understand what during winter months? Was that coolant change a year ago the first and only coolant change? Did you drain the engine or just dump and refill the radiator? What coolant was used?
    I know it's a lot of questions but this is somewhat of a hot topic for pre2014 tundras...
    2mchfun likes this.
  6. Aug 18, 2025 at 2:00 PM
    rocketdog
    Wouldn’t there be coolant in the oil with a blown head gasket?
    SBGibson likes this.
  7. Aug 18, 2025 at 2:02 PM
    rocketdog
    Drained and flushed the engine, I used recommend coolant for Toyota, orange stuff.
  8. Aug 18, 2025 at 2:02 PM
    AZBoatHauler
    So.Arizona
    Not necessarily. Sounds like it's leaking into the cylinder. You probably have exhaust gases in your coolant - that would confirm a blown HG. As would inspecting the cylinder for shiny clean.
  9. Aug 18, 2025 at 2:04 PM
    AZBoatHauler
    So.Arizona
    Ouch. No Toyota coolant is orange. Orange is for domestics. Pink or red for Toyotas.
    what did you use to flush the engine?
    ToyoMafia, Fobroader, 2mchfun and 3 others like this.
  10. Aug 18, 2025 at 2:07 PM
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    $4500 for a harness you didn’t need is ridiculous. Sounds like they loaded the parts cannon for you.
    Ready, aim, FIRE!
    There goes your bank account. Get a remanufacture for 8K and find an independent shop to swap it out.
    woods, joseph_womack, 2mchfun and 3 others like this.
  11. Aug 18, 2025 at 2:07 PM
    rocketdog
    Thinking that the coolant was beyond its freeze protection capacity causing head damage or gasket failure during a low temperature event. Winter months
  12. Aug 18, 2025 at 2:07 PM
    bflooks
    bflooks New Member
    Metrowest MA
    ummm, not sure where you are located, but there are a number of examples on this site of both salvage yard and remanufactured engines getting swapped in for ~$10k total. I'm not even close to $25k and I have a built long block and billet fuel rails included in my cost. You're doing the right thing to get other opinions. They obviously don't want to figure it out for you, or they are hoping you will sell it to them.
    OldGuy03, 2mchfun, mqqn and 1 other person like this.
  13. Aug 18, 2025 at 2:10 PM
    AZBoatHauler
    So.Arizona
    Most times when a head gasket fails - it's nothing to do with cold / freezing temps. That cracks blocks. Using incompatible coolant definitely can contribute to head gasket failure.
    OldGuy03, 2mchfun and Black Wolf like this.
  14. Aug 18, 2025 at 2:10 PM
    yakeng
    Yea, it’s like they priced it to rebuild a Turd- Gen short block.
    OldGuy03 likes this.
  15. Aug 18, 2025 at 2:10 PM
    AZBoatHauler
    So.Arizona
    Whoever sold him the harness is incompetent, a crook, or both.
  16. Aug 18, 2025 at 2:10 PM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    In this context it was: Ready, FIRE!, aim. Or they skipped the last one altogether.
  17. Aug 18, 2025 at 2:11 PM
    rocketdog
    My mistake, pink! Drained the radiator, ran the engine to circulate then drain again.
  18. Aug 18, 2025 at 2:19 PM
    rocketdog
    Thanks all for the reply’s! Gives me some ideas moving forward. Will post up how it all comes out!
  19. Aug 18, 2025 at 2:22 PM
    yakeng
    What dealership was it?
  20. Aug 18, 2025 at 2:54 PM
    rocketdog
    Durango Motor Co. Toyota dealership in Durango Colorado
    hey smell this and 2mchfun like this.
  21. Aug 18, 2025 at 3:05 PM
    mqqn
    mqqn New Member
    Andy
    2019 Tundra SR5 4.6L 2WD
    FuegoMCS and rocketdog[OP] like this.
  22. Aug 18, 2025 at 3:09 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    If initial diagnostics is correct with misfire 6 and 8 through codes ... I would start there
    2mchfun likes this.
  23. Aug 18, 2025 at 3:21 PM
    Call Yota corp line. Report what transpired and the cost.
    woods, Mater and 2mchfun like this.
  24. Aug 18, 2025 at 3:45 PM
    After warranty, no way in hell would any make or model vehicle of mine go to a dealership. They are parts swappers. 25k for an engine is ridiculous even with 25 hours R&R book time.
    snivilous, OldGuy03, T-Rex266 and 2 others like this.
  25. Aug 18, 2025 at 4:13 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Valley coolant leak?? What cylinders were impacted??
  26. Aug 18, 2025 at 4:29 PM
    2mchfun
    This whole mess is a horror story! First off, maybe suddenly just sucked in a plastic bag or similar and isn't getting air. Check for air flow. Then check for fuel pressure and overall fuel system. Lastly, check for fire. If all good, go on to boroscope plug bores, check compression, and test coolant for head gasket leaks. If all good there and runs like crap check for clogged catalytic converter. DO NOT just order an engine until a thourough checklist is done. You could just find a bad brain was the real problem after you swapped the engine. Also, grounds and battery terminals, be sure those are good!
    mqqn, NewImprovedRon and bflooks like this.
  27. Aug 18, 2025 at 6:08 PM
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
    It would be nice to have the details of their diagnostics that made them say the engine needs to be replaced if your only symptom is misfiring.
    2mchfun likes this.
  28. Aug 18, 2025 at 6:22 PM
    2mchfun
    Any recent fuel ups? Might just be bad gas such as having water in it or the delivery driver put the hose into the wrong fuel port and you have diesel mixed in the tank.
  29. Aug 18, 2025 at 8:10 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    I thinks it's obvious by now, but don't go back to that dealer. I'll also reiterate that there is now way that the cold had anything to do with any head gaskets failures.
    2mchfun, Leo's first and T-Rex266 like this.
  30. Aug 19, 2025 at 6:28 AM
    xjokerz
    xjokerz New Member
    Wow this is scary for somebody like myself who is interested in a 2nd gen truck. 115k miles? That's unfortunately the mileage where my budget allows, since these trucks seemingly are appreciating.
    rocketdog[OP] and Leo's first like this.
