5.7 Crewmax 2wd I don't tow. Any benefit to adding a rear sway bar ??
Discussion in '2nd Gen Tundras (2007-2013)' started by 10 Bears, Dec 18, 2024.
  1. Dec 18, 2024 at 11:08 AM
    10 Bears
    10 Bears [OP] New Member
    11 CREW 5.7
    None at the moment
    I see many Tundras both with and without. Any benefit for my application ?
    It's my daily driver.
  2. Dec 18, 2024 at 11:11 AM
    AZBoatHauler
    So.Arizona
    You’ll get less body roll in high speed turns. That’s about it.
    10 Bears[OP] likes this.
  3. Dec 18, 2024 at 11:15 AM
    Fobroader
    Fobroader New Member
    Alberta
    2020 Platinum
    I found the handling on curves and on/off ramps to be way better after I threw mine on. Infact, it was so good, I'm getting the matching front sway bar tomorrow.
  4. Dec 18, 2024 at 11:19 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Had it for about 3-4 years. Had taken it off this summer, for extra suspension articulation. Sway bar sacrifices offroading capability. Also have another vehicle that is more fun to drive around the corners.
    I may be adding it for my long annual overlanding trip when I have a canoe on top of Leer cap. No real offroading, just driving a lot of unpaved roads. Sway bar makes the most difference in such setup.
  5. Dec 22, 2024 at 1:01 PM
    fixnfly
    fixnfly New Member
    08 double cab 5.7
    I added one a few years ago.
    I Don't notice it much with an empty bed but when I put in my 900+lb ATV, it does make a noticeable difference.
