5.3 LS brand new build
Discussion in 'Marketplace - Other' started by skip1980, Nov 29, 2024.
  1. Nov 29, 2024 at 1:02 PM
    skip1980
    skip1980 [OP] New Member
    Columbia, Missouri
    Brand new build fresh from machine shop. 5.3 24x bored .020 with new pistons, rings and bearings throughout. Head have fresh valve job. All new gaskets and seals. New Sloppy stage 1 cam, LS7 lifters and trays. New melling 10296 oil pump. BTR springs. Trunion bearing upgrade. Chromoloy pushrods. New timing chain. Arp rod bolts, head bolts, cam bolts and crank bolt. Has f- body oil pan. Complete with spark plugs, flywheel, water pump, p/s pump and alternator bracket. Have truck intake also if wanted. $6,500. Will deliver within 50 miles.
    Black@Blue19 likes this.
