5.29 Nitro Gear Oil Recommendation
Discussion in 'Performance and Tuning' started by matictundra, Feb 18, 2019.
  1. Feb 18, 2019 at 7:24 AM
    matictundra
    matictundra [OP] New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    I'm upgrading my gears to 5.29 soon. Any diff oil recommendations besides using Nitro's oil?
    Erichudgins and dirtydeeds like this.
  2. Feb 18, 2019 at 8:10 AM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Lucas Oil.
    CaptRussia253, 831Tun and dirtydeeds like this.
  3. Feb 18, 2019 at 8:12 AM
    Spvrtan
    Kris
    San Diego, CA
    To be precise, this:
    Lucas 10045 Heavy Duty 85/140 Gear Oil - 1 Gallon
    matictundra[OP] and dirtydeeds like this.
  4. Feb 18, 2019 at 8:45 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Agreed^ the thickest oil you can find.
    TRD15559, 831Tun and matictundra[OP] like this.
  5. Feb 18, 2019 at 9:03 PM
    DIablo_AD
    DIablo_AD New Member
    Diablo
    2014 double Cab
    I would say stay with original toyota oil. It rund really great on my 4.88
  6. Feb 18, 2019 at 9:29 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Everything changes if you're running an ARB locker. Nitro recommends synthetic, can't use synthetic with the locker.
    TRD15559 likes this.
  7. Feb 18, 2019 at 9:32 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Nearing the end of the break-in so I'll check out the Lucas as long as it's not synthetic.
  8. Feb 18, 2019 at 10:03 PM
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    Schaefer makes some really good gear oil. I’m running 80w-140 non synthetic in my rear diff with an lsd. I have the straight 90w in the front diff and t-case. The shop that installed my 4:88’s uses it exclusively and highly recommends it.
    I also believe the Nitro gear oil is made by Schaefer.
    831Tun likes this.
  9. Feb 18, 2019 at 10:42 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Thanks John, good info. Wait,,,, what am I saying? I didn't start this thread...LOL
  10. Feb 26, 2019 at 2:54 PM
    matictundra
    Franco
    AZ
    Why? Seal not compatible?
    831Tun[QUOTED] likes this.
  11. Feb 26, 2019 at 2:54 PM
    matictundra
    Franco
    AZ
    What's the front and rear diff oil capacities?
  12. Feb 26, 2019 at 4:29 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Yeah, it's the seal/s in the locker that aren't compatible with synthetic oil.
    Erichudgins likes this.
  13. Mar 25, 2019 at 2:35 AM
    Bo-Hunter
    Bo-Hunter I like fast
    Greg
    NOVA
    2009 RW 4x4 Truck
    Long Travel, DC Shortbed
    As long as you use a pure synthetic without ANY additives. Motul is the only one I have found that makes a synthetic without the additives that adversely effect the soft metals on the seals, bearing keepers and copper tubing inside the ARB locker.
    831Tun likes this.
  14. Mar 22, 2021 at 5:33 AM
    TravisJr
    TravisJr New Member
    2001 AC SR5 4WD, 2010 DC SR5 4WD
    Lots o’ mods
    Bumping this instead of starting a new thread. Next week I’ll be putting Nitro 5.29s and an Auburn LSD in my 2011 DC. Nitro recommends synthetic, while Auburn is specific about using non-synthetic. Any advice? Auburn gear oil in the rear with the LSD and synthetic up front, or am I getting too deep in the weeds?
    831Tun likes this.
  15. Mar 22, 2021 at 8:10 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    There's an additive in some synthetic oils that causes a problem.... at least for ARB lockers. Sorry I forget what it is and it may be different for Auburn. But the additive causes seals to fail. @osidepunker knows what this is, he's the one that told me this. i run regular oil in my rear diff and synthetic in the front diff. I think Alex is really busy these days and won't respond so maybe I'll ask him and see if I can get the name of the additive.
  16. Mar 22, 2021 at 8:43 AM
    jc153
    San Diego
    Definitely use non-synthetic with your Auburn lsd. Synthetic doesn’t play nice with the clutches in the lsd. Also I would use the lsd additive recommended by Auburn.
    831Tun likes this.
  17. Mar 22, 2021 at 9:01 AM
    TravisJr
    TravisJr New Member
    Lots o’ mods
    That’s the general vibe I got from reading the threads here on LSD installs. Have a ton of Auburn gear oil and the additive ready to go. Just being cautious about the gears. I plan on being conservative with the heat cycling, and will do a fluid swap at 500 miles on, so perhaps the heat issues with the non-synthetic won’t be as much of an issue.
  18. Mar 22, 2021 at 12:04 PM
    dirtydeeds
    Keith
    USA
    I am going to contact Nitro and get a solid answer for you!!
    Thanks, Shawna
    831Tun and SC_TRD like this.
  19. Mar 22, 2021 at 12:08 PM
    TravisJr
    TravisJr New Member
    Lots o’ mods
    Awesome, thanks!
  20. Mar 22, 2021 at 12:49 PM
    dirtydeeds
    Keith
    USA
    From Nitro:
    We use our synthetic oil on every job we do so you can do it or not either or is works.
    Differential Expert, Inside Sales
  21. Mar 22, 2021 at 4:07 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    :rofl::rofl:
  22. Mar 22, 2021 at 4:33 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Warren, which oil did you end up going with?
  23. Mar 22, 2021 at 7:08 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Hey Cruz, I run Lucas 85-140 in the rear and Amsoil 85-140 synthetic in the front (no front locker).
    Cruzer[QUOTED] likes this.
  24. Mar 22, 2021 at 8:16 PM
    Fspmdt
    Fspmdt New Member
    2016 tundra 1794
    Bam 8 exhaust 285/70 18 ridges 4:88 gears, auburn lsd 6112s SPC UCA
    i also run lucas 85/140 in the rear with my nitro gears and auburn lsd. I run nitro syn in the front
  25. Mar 23, 2021 at 7:06 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Thanks Warren! Looks like I'll be flushing out the front and rear.
    SC_TRD and 831Tun[QUOTED] like this.
  26. Mar 23, 2021 at 7:19 AM
    TravisJr
    TravisJr New Member
    Lots o’ mods
    So I called Auburn directly today and spoke with a very nice lady. She strongly recommended sticking with non-synthetic 80W90 and the friction additive for the LSD. She seemed a little reluctant to speak directly against what Nitro recommended, but did not seem to think it was an absolute must to run super heavy gear oil unless problems arose. Probably going to start there, and adjust if necessary.
    jc153 likes this.
  27. Mar 23, 2021 at 3:11 PM
    jc153
    San Diego
    When I spoke with Auburn Gear a while back, this is what they recommend for their LSD in a Tundra.
    Use 80-90w oil
    Only use Auburn, GM or Ford lsd friction modifier
    Don't use Lucas oil, (reason: it’s noisy) :anonymous:
    Don't use synthetic oil
    Don't use oil that already has friction modifier in it
    If you use Auburn’s proprietary oil and additive you get a 1 year extension on their warranty
    831Tun likes this.
  28. Apr 1, 2021 at 10:31 AM
    5.7TRDProm
    5.7TRDProm What's bothering you?
    Dara
    2018 Cement Tundra SR5
    All stock-ish. Powdercoated blue suspension.
    where are you finding amsoil 85/140? I only see 80/140 in a 5gal pail available
  29. Apr 1, 2021 at 10:45 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Hmm, that's all I see on their website too. I ordered directly from Amsoil about a yr ago and received it in quarts. I'll see later if I can find a partial quart somewhere in the shop.
    5.7TRDProm[QUOTED] likes this.
  30. Apr 1, 2021 at 10:50 AM
    5.7TRDProm
    Dara
    okay cool thanks. I just finally got regeared and looking to get some gear oil order and set aside to change out after the break in.
