5.29 in a 4.6L
Discussion in '2.5 Gen Tundras (2014-2021)' started by KLLVMDCL, Mar 14, 2019.
  1. Mar 14, 2019 at 5:36 AM
    KLLVMDCL
    KLLVMDCL [OP] New Member
    Brandon
    Austin, Texas
    2017 Super White DC SR5
  2. Mar 14, 2019 at 5:53 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Maybe you can buy 5.29 gears, but will they fit in the differential housing? Reusing a 3.91 ratio pinion with a 5.29 ring gear does sound a little f'd up. Might want to consult the vendor's technical service for reassurance. Don't forget to fill us in.
  3. Mar 14, 2019 at 6:13 AM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    Call manufacture find out exactly what parts you will need make sure you get the correct part numbers
    trayday and JohnLakeman like this.
  4. Mar 14, 2019 at 6:16 AM
    ToyotaTundraMike
    2015 Tundra
    What size tires you running?
  5. Mar 14, 2019 at 7:02 AM
    Cfincke
    San Antonio
    Call Nitro and confirm if that gear for a 97 and older land cruiser will work in the tundra 9.5 rear end. I would think if it worked, nitro would have added tundra 9.5 as a supported vehicle for that gear
  6. Mar 14, 2019 at 7:07 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    There are 2 different generations of 9.5 axles. Call for sure and double check the spline counts to ensure you’re seeing the correct stuff
  7. Mar 14, 2019 at 7:45 AM
    KLLVMDCL
    Brandon
    Austin, Texas
    gonna be running 35s
  8. Mar 14, 2019 at 7:47 AM
    KLLVMDCL
    Brandon
    Austin, Texas
    good to know, the only info ive been able to find on regearing a 4.6 was from an old post by @dirtydeeds
  9. Mar 14, 2019 at 7:48 AM
    KLLVMDCL
    Brandon
    Austin, Texas
    thats why i was unsure of weather it was the correct install kit. guess im gonna have to bite the bullet and call nitro to confirm
  10. Jan 19, 2023 at 7:06 PM
    _steezysr5
    _steezysr5 New Member
    Instagram _steezyse Eibach pro lift stage 1 3.5/1.5 Rough country shims/block Methods nv305 double black 18x9 +25 Bfg ko2 35 12.5 Alpharex pro series headlights/taillights Lasfit ls plus series led Armordillo Hood Grille Insert with Led Lights Bakflip mx4 tri fold tonneau cover 5 inch iboard running board Pedal commander RCI Transmission and catalytic converter shield Nameplate overlays 5% tint all around Titan wheel spacer 1 inch Weather mats by 3dmatsusa Rydonair 7 inch Gplus third brake light Paint-matched hood bulge, grille surround, front and rear bumper overlays from Ecoological (midnight black metallic) Mbrp dual rear exit exhaust (mimics trd exhaust sound) yet to install, currently just a muffler delete
    Did you go through regearing your 4.6? Looking to do the same on mine.
  11. Jan 19, 2023 at 7:46 PM
    2mchfun
    Pretty old thread! Welcome to the forum!
    _steezysr5[QUOTED] likes this.
