4x4 usage interval?
Discussion in '2.5 Gen Tundras (2014-2021)' started by bstringrandy, Oct 3, 2022.
  1. Oct 3, 2022 at 1:09 PM
    bstringrandy
    bstringrandy [OP] New Member
    Randy
    Middleburg, FL
    2021 Tundra TRD Pro
    I have a question. I bought the truck back in Jan 22 with 12,400 miles on it. It’s a 21 TRD Pro. Since then I’ve put about 2000 miles it. I haven’t had a chance to take it off road yet. I think I saw someone reference the Tundra transfer case as lube it or lose it on another post. Is this an issue? Should I find a dirt road every so often and engage 4-HI for a bit? If so, how long should it go between uses? This is my first 4x4 so I have no idea if this is a thing or not. TIA for the help!
  2. Oct 3, 2022 at 1:10 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    It would not be a bad idea to do that. I do think the manuals recommendation is a little overkill for alot of people but its fine for me since i regularly offroad at least a couple times a month. Alternatively you could just engage and disengage it in your driveway once in a while, not ideal but its better than nothing.
  3. Oct 3, 2022 at 1:11 PM
    Taco-Spike
    Two Trucks
    If you're averaging 2000 miles since Jan, a few times a year should be fine. Also ^
    I've only done about 2k miles since Feb. Engaged 4x4 a few times, a few hundred yards each time
    bstringrandy[OP] likes this.
  4. Oct 3, 2022 at 1:14 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    For someone who doesn't use/need 4WD I recommend cycling it on a couple of times a year. Drive down a straight stretch of road, kick on 4wd, drive a mile or two, turn it off. Easy as that.
  5. Oct 3, 2022 at 1:18 PM
    MadMaxCanon
    sometimes its hard to engage the 4wd if you are on a perfect road. I found that if you put one front tire up on the curb, the system "thinks" there slip and general unevenness, so it will engage easier.
    bulldog93 and bstringrandy[OP] like this.
  6. Oct 3, 2022 at 1:26 PM
    memario1214
    Colton
    Missoula, MT
    We're not really asking for there to be any special power distribution taking place. All we want is for the transfer case to formally engage the front drive axles. All of that should engage very willingly and easily on a straight and level surface.
    To be honest do you want to know when I have had the most trouble getting 4WD to engage? When I am stuck or cattywampus out in the woods and ALL I NEED is the damn 4wd to kick in so that I can get out. So here I am rocking between D and R while 4wd decides whether or not it will grace me with its presence. :rofl:
  7. Oct 3, 2022 at 1:30 PM
    MadMaxCanon
    haha i been there, i have to let it roll back or something on a trail and then it will finally shift. I miss my old manual stick shift transfer case.
  8. Oct 3, 2022 at 3:37 PM
    Wallygator
    I believe the manual calls for 10 miles a month. I engage it when it rains and drive down straight roads if I haven't been off road in a while. Also I try to put it in 4 low about every six months if not used off road.
    omgboost and bstringrandy[OP] like this.
  9. Oct 4, 2022 at 4:04 AM
    737fixer
    737fixer New Member
    Everything everyone said is fine. The failure point with our cases is actually the actuator. Any time your on a bit of dead straight road between red lights just run it in Hi for a bit and back out. Keeping the system lubed is great but keeping the actuator moving is key.
    Joe333x and bstringrandy[OP] like this.
  10. Oct 4, 2022 at 4:43 AM
    0.S.T.
    0.S.T. New Member
    EAST COAST
    2007 BLACK TUNDRA 4X4 CREWMAX LIMITED 5.7 LITER
    Use It or Lose It.
    Once a month, I use 4H & 4L just to cycle it. I usually go to my secret dirt/gravel parking lot and drive for a bit. Do it anywhere except the dry streets. I have had several friends lose their 4x4 drive system because they never engaged it at all.
    O.S.T.
    Wallygator and bstringrandy[OP] like this.
  11. Oct 4, 2022 at 9:58 AM
    bstringrandy
    Randy
    Middleburg, FL
    2021 Tundra TRD Pro
    Thanks for all the inputs! This morning, I took her out to the nearest dirt road. Went a mile or so in 4-HI then stopped and used 4-LO for about 1/4 mile. All worked as advertised so I’m good to go for another 3 months or so! :)
    Joe333x and Wallygator like this.
  12. Oct 5, 2022 at 6:29 PM
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    Agreed, the recommendation in the manual is extremely overkill.
    MadMaxCanon[QUOTED] likes this.
  13. Oct 5, 2022 at 7:38 PM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    I do 10 miles 4 hi on straight freeway in the slow lane first week of each month.
    I need to get a better routine for the 4 LO.
  14. Oct 8, 2022 at 11:29 AM
    Wallygator
    Yeah those engineers at Toyota don't have a clue.:anonymous:
  15. Oct 9, 2022 at 6:03 AM
    JJtruckon
    JJtruckon New Member
    JJ
    2018 Tundra
    Undercoating
    Not a huge fan of 10 minutes or even 2 minutes. Engaging the 4wd and clicking out is all that is needed.
