4x4 not engaging?
Discussion in '1st Gen Tundras (2000-2006)' started by TF97, Dec 17, 2020.
  1. Dec 17, 2020 at 1:00 PM
    TF97
    TF97 [OP] New Member
    2004 Double Cab V8 4x4 SR5
    Raptor-style amber grille lights
    First time poster.
    Picked up a 2004 double cab SR5 4x4 in June of 2020 (now is December). 4.7 V8 running great with 165k on the odometer.
    Just got hit with a snowstorm, and wasn't able to engage the 4wd. When I push the 4HI button, I can hear a clunk sound coming from the front end, but the light just flashes, and the 4x4 does not engage.
    I've done some reading on this, seems like the most common culprits are a bad position sensor or a bad actuator motor on the transfer case.
    Anybody else had this problem, and if so, what did you do to fix it?
  2. Dec 17, 2020 at 1:48 PM
    Sunnier
    Sunny
    San Diego, CA
    Bump, so you get another pass on the main page. Good luck!
  3. Dec 17, 2020 at 1:55 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Were you moving while you tried it? My truck shifts into 4HI a lot smoother when I'm already moving. There is a chance the previous owner never engaged 4WD and the actuator is frozen like you mentioned. The owners manual states we're supposed to driver a certain amount of miles each month in 4WD.
    @empty_lord might have some advice for you.
  4. Dec 17, 2020 at 2:21 PM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    +1 on moving when engaging 4HI.
  5. Dec 17, 2020 at 2:25 PM
    TF97
    I've tried engaging 4HI while moving too. Pushed the button and drove around under 20 for 5-10 minutes, same result- can hear something trying to engage from the front end after pushing the button, but the light just flashes and no 4wd.
  6. Dec 17, 2020 at 3:32 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    If you hear a clicking from the front noise that “should” be the front diff actuator, you need to pinpoint what your hearing. Technically the front diff shouldn’t engage till the transfer case is in gear, so you might actually be hearing the transferscase shift into 4hi but the front diff is stuck open
    N84434 likes this.
  7. Dec 17, 2020 at 3:48 PM
    TF97
    Yes, my bad. I believe it is the transfer case actuator I'm hearing. I'm assuming the actuator itself is good since I can hear it trying to engage, so the problem is possibly somewhere else. Maybe the 4HI position sensor?
  8. Dec 17, 2020 at 4:04 PM
    Is this the first time you've tried using the 4wd? Did it work when you originally purchased the truck?
  9. Dec 17, 2020 at 4:48 PM
    TF97
    I didn't think to try it out before purchasing, so just realizing the problem now
  10. Dec 17, 2020 at 4:53 PM
    GIN•OKUMA
    GIN•OKUMA Can’t get to SSEM from there. RGBA1
    Fish
    26.57°
    Noun; a machine, usually with wheels and an engine, used for transporting people or goods, especially on land
    Try going in reverse for a 30 yards or so with it engaged? Then go forward and maybe reverse again if it doesn’t work the first time.
    Schcoman likes this.
  11. Dec 17, 2020 at 5:01 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    The actuator on the front diff can partially 'sieze' in place if not used every so often. The grease will 'set' or 'harden' enough to bind the actuator.
    Sometimes you can turn 4x4 on/off to free it up, sometimes you can bang on the actuator with a deadblow or rubber mallet to free it up too while trying to engage it.
  12. Dec 17, 2020 at 5:42 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    You can try the dead blow approach, but more than likely a new front actuator is in your future. I replaced both of mine back during the summer.
    If you do end up replacing the front ADD actuator, drain the gear oil first, because it will run out the actuator mount area when you remove the actuator. Refill with fresh gear lube after the actuator is replaced.
  13. Dec 17, 2020 at 7:13 PM
    empty_lord
    05 rollover special
    this
    N84434[QUOTED] likes this.
  14. Dec 19, 2020 at 10:12 PM
    Clebner
    Clebner New Member
    2004 double cab limited TRD
    On my Tundra 4wd will only engage after I press the button and turn the vehicle off then back on.
  15. Dec 20, 2020 at 3:16 AM
    NetGnome
    NetGnome New Member
    NJ
    2003 RC V8 4wd, 2007 Sequoia V8 4wd
    Removed lots of rust.
    There are some YouTube videos on ADD repair. The contacts inside the ADD usually need cleaning.
