4wd works, but transfer case is making noise
Discussion in '2nd Gen Tundras (2007-2013)' started by UseToDriveFords, Feb 16, 2021.
  1. Feb 16, 2021 at 6:40 AM
    UseToDriveFords
    UseToDriveFords [OP] New Member
    During this crazy weather we are having, I got out to deliver firewood to a friend and used 4Hi for bit. It worked, but was immediately noisy - almost like a clicking that increased and decreased with load and speed. Checked underneath at a gas station to see if anything obvious underneath amiss, but saw nothing. No fluids leaking and no smell of anything wrong. Is this a low fluid issue? Bad transfer case? Anyone experienced this?
  2. Feb 16, 2021 at 8:49 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    That could be the traction control doing what it does. Find some dry road and try driving in a straight line to see if the noise goes away.
  3. Feb 17, 2021 at 9:08 AM
    UseToDriveFords
    Definitely a drive line issue. Took it to my mechanic to see if they could just check fluid and test drive. Transfer case slightly low, but no leaks. Topped it off and checked for any metal in fluid. Nothing loose and fluid clean. They think it is actually in the front diff. Once everything melts here we will do run out tests while on a lift to isolate the noise and confirm. May need to replace the diff. Thankfully used assemblies are not expensive. 4hi and 4low are working, just noisy.
    also wondering if this would be a good time to consider a diff upgrade to something that locks - i guess that would no longer be the cheap route.
    Silverghost likes this.
  4. Feb 17, 2021 at 9:10 AM
    audiowize
    Paul B.
    The driver's side needle bearing is notorious for going out, that that tends to make a noise when you aren't in 4WD. Still, the ECGS bushing install is no big deal if that's what it is. Diff replacement should be a last resort.
  5. Feb 17, 2021 at 9:24 AM
    UseToDriveFords
    That was an option that was mentioned by the shop. We will just see what a more thorough diagnostic shows next week some time.
  6. Feb 18, 2021 at 7:08 AM
    UseToDriveFords
    update: drove it to the store in the new snow and ice. Used 4Hi just when needed. on the way home sitting at a light in 2Hi and Trac control, ABS, and 4HI/4Low lights all came on dash. 4hi and low flashing. Not sure what it means or how this and the clicking are related.
  7. Sep 14, 2021 at 4:52 PM
    Ktate
    Ktate New Member
    2007 RCSB SR5 TRD 4x4
    Any update?
  8. Sep 14, 2021 at 8:47 PM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Truck decided it wanted to be RWD?
