4WD stuck on
Discussion in '2.5 Gen Tundras (2014-2021)' started by Steplift20, Feb 3, 2025.
  1. Feb 3, 2025 at 10:59 AM
    Steplift20
    Steplift20 [OP] New Member
    2018 Tundra
    2018 5.7 engine
    Today I had to put my truck in 4 WD to get out of my driveway cause of snow. The problem is when I went to go back into 2 we it just kept blinking. It took me over a minute for it to go back into 2wd. I switched the knob back to 4wd then back again and finally it wen5 to 2 wd. I don’t use 4wd often maybe only two times this year. Is there any5hing I can do to fix this issue
  2. Feb 3, 2025 at 11:07 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    You need to engage/exercise 4wd every so often to keep it functioning well.
  3. Feb 3, 2025 at 11:07 AM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    That’s normal, the truck protects itself from engaging/disengaging. You usually have to be flat idling or flat sub 50mph at low rpm and it’ll switch in 30-60 seconds. Turning/inclines/declines/rpm seems to delay the switch. I use mine daily for work and play, you have to be strategic on when to flip it.
    You should be putting it into 4hi monthly for a few miles on a straight road during a regular drive.
  4. Feb 3, 2025 at 11:47 AM
    Lifer
    Lifer New Member
    Vince
    2000 Ltd 4x4 2008 SR5 4x4 LB 2021 SR 4x4 LB
    Fab tech on the 2000
    All three of my trucks I finding backing up disengages 4wd much more easily than forward.
    Philogynist, Steplift20[OP] and ejes like this.
  5. Feb 3, 2025 at 11:59 AM
    AZBoatHauler
    So.Arizona
    Your owner’s manual says to drive 10 miles every month in 4x4 to keep the system functioning properly.
  6. Feb 3, 2025 at 12:06 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    :anonymous:
    ZappBrannigan and Mdl like this.
  7. Feb 3, 2025 at 4:25 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Beat me to it.
    Lifer[QUOTED] likes this.
  8. Feb 3, 2025 at 4:44 PM
    Steplift20
    2018 Tundra
    20 miles a month? I don’t do ten miles a month
    I think 5he electronics suck nothing but problems. A I had a 94 Chevy and never had a problem even when I junked it ( rust got the better of the truck);the 4wd worked flawless. But I will try to engage mine a few times a month
  9. Feb 3, 2025 at 6:19 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Worked at an aluminum mill in WV. They had a Bronco that was used primarily for clearing snow. Old style 4wd. 4WD went out. After repair it had a sticker on dash stating that this vehicle must be driven x miles in 4wd monthly. It was important even in the old days. I have owned 4x4s since early 80s and always tried to use monthly.
  10. Feb 3, 2025 at 7:37 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I usually throw mine in drive a few feet and reverse a few feet and that does the trick when it’s being bitchy.
  11. Feb 3, 2025 at 9:14 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Also worked on the old manual locking hubs. Friend drove his 70 something F150 on pavement in 4wd. When we stopped the hubs would not unlock. Driving in reverse fixed it.
  12. Feb 3, 2025 at 9:40 PM
    vtown76
    vtown76 New Member
    Likely nothing to do with not using it frequently, but more to do with shifting in/out of your part time 4wd with drivetrain binding as a result of turning. Part time systems only like to go in or out when the truck is / has been going straight long enough for any rotational inequity between axels to equalize and not be under load.
  13. Feb 3, 2025 at 9:47 PM
    Gort
    Gort New Member
    Canada
    2020 Tundra SR5+
    Lube it or lose it! Gotta engage it every once in a while.
    AZBoatHauler likes this.
  14. Feb 4, 2025 at 12:56 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The actuator motors on the transfer case and front differential need to be worked or they will seize up. It’s not so much a distance requirement but rather just the act of engaging 4H, then 4L then back to 2H. Do this little exercise twice a month and you will be trouble free.
