4WD, really?
Discussion in '1st Gen Tundras (2000-2006)' started by jammer88, Mar 25, 2019.
  1. Mar 25, 2019 at 12:57 PM
    jammer88
    jammer88 [OP] New Member
    2000 white original 4WD
    K&N air filter, Gibson exhaust, KYB shocks, 17" wheels
    My 2000 tundra has 4WD emblems, but it's not really four wheel drive because it only drives one rear wheel (discovered in a moment of slush on the roadway. I would like to install posi on the rear only, but wonder if that is acceptable with the toyota system.
  2. Mar 25, 2019 at 1:00 PM
    blizz86
    blizz86 New Member
    I dont get it.. are you discovering that the diffs are open?
  3. Mar 25, 2019 at 1:12 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    One of the first mods I made to my '02 4WD was to install a Kazuma/TRD LSD, much better traction.
    TX-TRD1stGEN and Black Wolf like this.
  4. Mar 25, 2019 at 1:14 PM
    15whtrd
    15whtrd Mr. Blonde
    So your front differential is not engaging?
    GNTundra likes this.
  5. Mar 25, 2019 at 1:24 PM
    jammer88
    Shifting into 4wd, the front engages, shift out and only the right rear wheel drives. I would expect both wheels drive if I had LSD, but they don't so I want to install LSD on the rear. I found this out at 60 mph on a mountain road, went to my local dealer and asked if they could honestly label it as 4wd when the left rear doesn't drive as it would if LSD. Which number on the pumkin ID tag indicates whether or not it's LSD?
  6. Mar 25, 2019 at 1:28 PM
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    A two wheel drive without Limited slip is still called a two wheel drive, not one wheel drive.
    AZTundra, Aerindel and blizz86 like this.
  7. Mar 25, 2019 at 1:29 PM
    blizz86
    blizz86 New Member
    Shouldnt really be going 60mph in 4wd either.
    Mr. Pink and landphil like this.
  8. Mar 25, 2019 at 1:33 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Gen 1 tundras have tons of options.
    Look into lockright systems. Full locker can be installed into your open diff
  9. Mar 25, 2019 at 1:33 PM
    Cement
    Cement ...
    2019 Cement Trundra TRD
    Does the 2000 not have the fake LSD switch? (2019 here; we can press a button and the system will work the brakes to limit slip)
  10. Mar 25, 2019 at 1:36 PM
    15whtrd
    15whtrd Mr. Blonde
    No. But they did offer a limited slip option.
  11. Mar 25, 2019 at 1:52 PM
    Cement
    Cement ...
    Gotcha
    15whtrd[QUOTED] likes this.
  12. Mar 25, 2019 at 1:59 PM
    Professional Hand Model
    Hand Protectors
    The 02’ came with the LSD as a package. Its a true LSD by Eaton/Kazuma. Cost when new on the sticker was $275.
  13. Mar 25, 2019 at 2:15 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Any 4wd truck with open differentials regardless of make would have had the same thing happen.
    speedtre and Aerindel like this.
  14. Mar 25, 2019 at 4:39 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    speedtre, lsaami and Casper421 like this.
  15. Jul 27, 2019 at 9:50 AM
    jammer88
    To clarify the discussion, my gripe about badging was that two wheel drive does not have a 2WD badge because it's assumed, yet a vehicle specifically badged as 4WD should be just that. The other note was that I was in two wheel drive at 60 mph, when I first discovered my truck (which was new to me) must have an open diff. My usual driver is an Audi S4 quattro, and there is no question about its ability in almost any condition (been known to push snow higher than the front bumper, even with 225/50 all season tires).
    I should have been more specific (mea culpa), I am looking to install LSD and that has been answered, so thank you.
  16. Jul 29, 2019 at 3:53 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    That's just the way a differential works. When one wheel loses traction, all the power is sent to that one wheel. It's not ideal -- in fact it's the exact opposite of what you'd want to happen.
    But to be clear, the 4WD designation refers to the relationship of power distribution between the front and rear axles. In a 4WD vehicle, the front and rear axles are "locked" together. Meaning if the rear axle spins one revolution, the front must also spin one revolution. Your Audi on the other hand is AWD, which means there's some means of "give" between the front and rear axles. I presume it's a viscous coupler, but I'm not sure as I don't follow Audi's technology closely.
    Adding limited slip to your Tundra's rear axle should help traction a lot.
