4wd Lights
Discussion in '1st Gen Tundras (2000-2006)' started by jamez34, Jun 28, 2021.
  1. Jun 28, 2021 at 3:33 PM
    jamez34
    jamez34 [OP] New Member
    03' Tundra
    Hey guys! I am new to the forum and decided to start off with an interesting problem. I went to use the 4wd on my truck the other day and all I got was some flashing 4wd lights that now won't go away.
    I put the truck in some dirt to make sure the front wheels weren't spinning and have been driving it. I put the truck up on my lift to take a look at the rear actuator and found that when the truck is in drive it is transferring power through the transfer case to the front axle but, the front wheels do not spin.
    Would this indicate that the transfer case is actually in 4wd and the front differential has not locked the front axles into the system? How can the TC be in 4wd but not the front differential?
  2. Jun 28, 2021 at 3:34 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Sounds like a classic stuck fromt diff actuator to me. Try tapping it with a hammer
    N84434 and jamez34[OP] like this.
  3. Jun 28, 2021 at 3:52 PM
    jamez34
    03' Tundra
    I gave that a shot with a heavy brass hammer, no luck. The truck won't un-select the 4wd from the TC either, I have been driving like this a couple thousand miles lol I bought a new TC with the TC actuator off of eBay for 250 dollars. I was wondering if maybe one of the switches on the actuator is no good, its a northeastern truck so new parts are always the easiest route.
  4. Jun 28, 2021 at 4:15 PM
    empty_lord
    05 rollover special
    the front actuator has limit switches inside it that if not tripped will not let the case shift out. but there is a slim chance the case doesnt know its in 4wd either.
    jamez34[QUOTED][OP] likes this.
  5. Jun 28, 2021 at 4:43 PM
    jamez34
    03' Tundra
    Is it possible to pull apart the front actuator to clean it just like the rear one? Or would buying a new actuator be my only option...
  6. Jun 28, 2021 at 4:44 PM
    empty_lord
    05 rollover special
    im sure someone has pulled them apart. but i have not nor know anyone that has
  7. Jun 28, 2021 at 4:55 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    I've been down this road, my man... You can try to remove the plastic cover to see the position of the contacts. You said the transfer case is engaging the front drive shaft?
    If thats the case, it's possible that the 2 actuators are out of sync with each other and the controller. You can remove the actuator from the front diff and see what position the AAD is in. The fork on the actuator moves a lock ring to the drivers side to engage the front differential. You can see what position the actuator is stuck in when you have 4hi selected.
    Hope that makes sense.
    jamez34[OP] likes this.
  8. Jun 29, 2021 at 12:15 PM
    jamez34
    03' Tundra
    Yeah it looks like the TC is engaged in 4 HI but the front differential is not locked in. When the truck is up on my lift and you put it in drive the TC is transfering power to the front driveshaft. I also can't seem to get the TC out of 4 HI, it looks like this may be some sort of fail safe as empty_lord suggested that is the front actuator is not satisfied then it will lock the TC in whatever state it is in and you can't get it out
  9. Jun 29, 2021 at 2:19 PM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Kill power, manually move everything into the 4hi position and then turn the key. This will entail removing the plastic covers on the actuators and very gingerly spinning the worm gear to rotate the actuator to the desired position.
    Once you have the system in 4hi, and power it up, theoretically it should tell you you're in 4hi, theoretically....
  10. May 16, 2022 at 7:59 AM
    jamez34
    03' Tundra
    So it has been a while since I started this thread but figured I would give some closure on it! It turned out to be be the actuator on the transfer case being now good. I swapped out the actuator with a good used unit and boom 4wd works again!
    des2mtn, bmf4069 and shifty` like this.
  11. May 16, 2022 at 8:11 AM
    shifty` All my rowdy friends have settled down
    Damn, same one you tried whacking with a hammer?
  12. May 16, 2022 at 4:24 PM
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    Brass hammers are cushy.
    In this case it sounds like the problem preexisted the whacks.
  13. May 16, 2022 at 4:40 PM
    jimf909[QUOTED] likes this.
  14. May 17, 2022 at 8:25 AM
    jamez34
    03' Tundra
    Yeah, it was pretty seized up. The cover was cracked so I suspect water kept getting in and eventually just caused it to seize after it hadn’t been used in a few months
    shifty`[QUOTED] likes this.
