4wd light on dash gone
Discussion in '1st Gen Tundras (2000-2006)' started by zman12, Mar 21, 2016.
  1. Mar 21, 2016 at 1:47 PM
    zman12
    zman12 [OP] New Member
    Alex
    2002 Burgandy Tundra Sr5
    Dick Cepek 16" wheels, Banks Monster exhaust, K&N filter, black 3" steelcraft running boards.
    Went to put the truck in 4wd the other day and the light on the dash did not come on. I checked all the fuses and none of them seemed to be burned out. Mechanically everything works fine just not sure if a bulb burned out or i just missed a fuse?
  2. Mar 21, 2016 at 2:13 PM
    I'm going to say the light is out if it engages / disengages from 4WD.
  3. Mar 21, 2016 at 2:25 PM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    Yes, I've had a few light burn out in the dash over the past few years, not hard to fix but most require a special bulb from Toyota. Just be careful cause after I fixed the light bulb my speedometer when bad and was over 300 bucks to fix... Don't know if it was coincidence or not but happened right after replacing the bulbs.
