4wd issue
Discussion in '2nd Gen Tundras (2007-2013)' started by MoxiToy, Feb 14, 2022.
  1. Feb 14, 2022 at 8:44 AM
    MoxiToy
    MoxiToy [OP] New Member
    2013 Tundra
    Hi all, new member here and a noob to 4wd's. We recently purchased a used 2013 Tundra 4wd and when I put it in 4hi it operates fine at speed but when I come to a full stop it feels like the emergency brake is on when I try to go forward and especially in reverse. I am scheduled for service at the local dealer in a week but figured I would give this forum a shot to see if anyone might have an idea what the issue is (or if it's entirely normal)?
    Thanks in advance
  2. Feb 14, 2022 at 8:50 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    hard to know exactly with your description but it is supposed to be a little harder to move from a stop with 4wd engaged because there is more of a tax on your power since it has to be distributed to the front as well. I have accidentally tried to move with the ebrake engaged and its very noticeable, if it actually feels like that, you may have an issue.
  3. Feb 14, 2022 at 8:50 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Are you turning the steering wheel when it feels like the emergency brake is on?
    Patch999 and gladecreekwy like this.
  4. Feb 23, 2022 at 5:19 PM
    MoxiToy
    2013 Tundra
    Nope.
  5. Feb 23, 2022 at 5:23 PM
    MoxiToy
    2013 Tundra
    Thanks, I just had the brakes replaced and they said everything looks ok.
    MadMaxCanon[QUOTED] likes this.
  6. Feb 23, 2022 at 5:54 PM
    ZPMAN
    Minnesota
    Are your tires all the same size? Also are they all about the same for wear? Kind of sounds like the 4×4 system is binding up, try it on a dirt road to see if it is still binding.
    Aerindel likes this.
  7. Feb 25, 2022 at 1:10 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    maybe your parking brake is engaged a little. any update?
  8. Feb 26, 2022 at 6:09 AM
    MoxiToy
    2013 Tundra
    Tires are same size and seem to be wearing normally. I'll keep my eye out for a dirt road and see what how it feels.
  9. Feb 26, 2022 at 6:13 AM
    MoxiToy
    2013 Tundra
    I've checked and double checked to ensure that I wasn't driving with the parking brake on. I had rotors and pads done last week at the dealer and mentioned the issue to them and they said the 4wd looked fine, so for the time being, I am going with "rookie mistake".
  10. Mar 2, 2022 at 1:53 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    you had them check the actual brake though? not just the pedal? i'm pretty sure my parking brake drags because it squeaks in reverse after i disengage it.
  11. Mar 2, 2022 at 1:58 PM
    coolbeans
    coolbeans New Member
    Maybe your brakes are sticking a bit.
  12. Mar 2, 2022 at 1:58 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    If it was the parking brake it would do it regardless of 4wd. With that said I have no suggestion OP besides have someone with mechanical knowledge drive it. Mine feels no different accelerating/decelerating in 4wd. Unless the transfer case or front diff are doing some weird shit, it should act nearly the same in 2hi and 4hi.
  13. Mar 9, 2022 at 9:28 AM
    MoxiToy
    2013 Tundra
    I can't say with any certainty. The Parking brake light has stopped going on randomly so I assume that whatever activates the light was resolved when they did the brakes.
