4wd flashing light and unusual noise, replacing actuator didn't help
Discussion in '2nd Gen Tundras (2007-2013)' started by Ssheets, Oct 4, 2023.
  1. Oct 4, 2023 at 8:41 PM
    Ssheets
    Ssheets [OP] New Member
    Stacie
    2012 toyota tundra rock warrior
    Trying to figure out a 2010 tundra 4wd problem. When switching into 4 wd the light flashes eight times and then a bunch of weird noise. It never does switch in. We replaced the one actuator that is recommended but that didn't help. Any advise would be helpful.
  2. Oct 5, 2023 at 9:12 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Here is a matrix, best way is an OBD2 reader that is able to read transmission and ABS codes as not all are equal.
  3. Oct 5, 2023 at 10:01 AM
    Ssheets
    Stacie
    Looks like the rear wheel sensor is the mostly culprit according to that chart.
  4. Oct 5, 2023 at 12:02 PM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    I was gonna ask, which actuator did they already replace? I am assuming when its in 2wd all the lights are off and the issue comes up when you try to switch to 4wd?
  5. Oct 5, 2023 at 2:26 PM
    Ssheets
    Stacie
    The one near the transfer case and yes when it's in 2wd no lights, when you try to switch to 4h the light flashes 8 times and then make some notices.
