4WD Engagement Delay
Discussion in 'Sequoia 2nd Gen (2008-2022)' started by MattB, Aug 18, 2024.
  1. Aug 18, 2024 at 3:56 PM
    MattB
    MattB [OP] New Member
    Tucson, AZ
    2013 Sequoia Platinum (also 2010 FJ Cruiser and 2020 Tacoma
    none
    New guy here - 2013 Sequoia bought recently
    When I engage the 4WD HI on relatively level pavement at, say, 30 MPH, the indicator light goes solid and the 4WD engages in a couple of seconds. That is what I observe on the FJ and Tacoma we also have in the family.
    But, if I engage the 4WD on a rougher dirt road at maybe 5-10 MPH, it takes several MINUTES or more to engage.
    Any ideas? I feel like it is getting ample time to sync up.
  2. Aug 24, 2024 at 9:38 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    It probably hasn't been engaged in a long time, keep doing it and it should get better.
    Some people set a "use it or lose it" reminder once a month for it.
  3. Aug 24, 2024 at 9:52 AM
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    Probably could check the transfer case fluid and front diff fluid, and, as said above, use it regularly or it will stop working, The solenoids need regular exercise to stay limber and useful
  4. Aug 24, 2024 at 11:04 AM
    MattB
    Tucson, AZ
    none
    All fluids checked or replaced since we bought it. I try to engage the 4WD weekly on our vehicles. The Sequoia was slow to change when we got it, and has gotten better. I am perplexed why the slow-speed rough-road engagement is so dramatically different from the medium-speed smooth road engagement.
    Thanks!
  5. Aug 31, 2024 at 3:27 AM
    Hat and Beard
    Hat and Beard New Member
    Southern New England
    2020 Toyota Sequoia TRD PRO
    As per owner's manual, on our 2020 TRD PRO the gearing change has to be done while stationary and in Neutral. I don't know if that applies to yours.
  6. Aug 31, 2024 at 4:50 AM
    MattB
    Tucson, AZ
    none
    Thanks! I just checked the 2013 manual, and shifting from 2HI to 4HI and back is allowed at under 62 MPH. Shifting from 4HI to 4LO requires the truck to be stopped and in neutral.
    The requirements may be different for the 2020 TRD PRO.
