4wd Drive train lubrication with RCI skids
Discussion in 'General Tundra Discussion' started by joe557, Jan 22, 2022.
  1. Jan 22, 2022 at 2:24 PM
    joe557
    joe557 [OP] New Member
    Joe
    2014 Crewmax SR5 4x4 TRD
    Bilstein 6112/5160s, durobumps, 1" CB shackles, RCI skids
    Is there a way to lube the 4wd shaft with RCI skids without removing the skids? How often does it need to be greased?
  2. Jan 22, 2022 at 2:33 PM
    AZBoatHauler
    So.Arizona
    If there is a way I haven’t found it. I grease mine whenever the plates are off. The driveshafts from 2018 forward have no zerks so I don’t worry about it too much but as luck has it I’ve never gone more than 15,000-20,000 miles.
    joe557[QUOTED][OP] likes this.
