4wd 4lo abs trac con lights all on
Discussion in 'New Member Introductions' started by Munz, Jan 14, 2024.
  1. Jan 14, 2024 at 8:08 PM
    Munz
    Munz [OP] New Member
    2013 tundra rock warrior
    Hello
    I have had three tacomas and a t100. Now have a 2013 tundra rock warrior crew max for about a year now. Love the truck! Bought it w 100000 miles on it and put about 10000 on it so far. Half of those miles are bumpy nv ut dirt roads. No rock crawling. Every so often might put it into 4wd for mud puddle. Just started using 4hi for a few snow storms here. A couple days ago went from 4hi to 2wd and 4wd 4lo started blinking and the abs and trac light came on and would not go off. Did all the normal stop go reverse stuff no results and would not go back into 4 wd. Drove another 30 min w no issues other than lights! Parked it for the weekend then drove it tonight all back to normal. Went into 4wd and out no problems no lights. ??
    Spend a lot of time in the middle of nowhere! Any recommendations
    Thanks for your time
    Munz
  2. Jan 15, 2024 at 4:24 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    The tranny and transfer case should be serviced every 60k miles. That may not have happened at 60k. Drain and fill on the tranny and check fluid color and smell in the transfer case. I'm having mine done this week for the 60k service.
    The Black Mamba likes this.
  3. Jan 15, 2024 at 5:16 AM
    Munz
    Good morning
    Appreciate the reply
    I had that done when I bought it.
    Bakershack likes this.
  4. Jan 15, 2024 at 7:31 AM
    The Black Mamba
    The Black Mamba He must increase, but I must decrease - John 3:30
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Welcome from the Great State of Texas!
  5. Jan 15, 2024 at 7:36 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    T-Rex266 likes this.
  6. Jan 15, 2024 at 7:45 AM
    wauto
    wauto New Member
    mike
    Check for misfire codes. When the warning lights go nuts it could be setting a hard code of some sort.
  7. Jan 15, 2024 at 10:02 AM
    Munz
    Thank you sir
    Will do
  8. Jan 15, 2024 at 7:46 PM
    Welcome from NY.
  9. Jan 15, 2024 at 7:49 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
