4lo / 4hi lights flashing, traction control, vsc, abs solid
Discussion in '2nd Gen Tundras (2007-2013)' started by spazbastian, Jul 27, 2024.
  1. Jul 27, 2024 at 12:18 AM
    spazbastian
    spazbastian [OP] New Member
    While driving my front right tire on my 2007 Tundra 4x4 went off a curb a little hard. About 30 minutes later of driving the above lights appeared on my dash. Anybody have any idea what this could be? I also have an issue where I get a crunching during hard breaking almost like a warped rotor despite brakes being good and wondering if this could be related.
    Have done some research and plan to start by checking out cv axels and wheel sensors but wondering if anybody has an idea.
  2. Jul 29, 2024 at 6:47 PM
    tyr0981
    tyr0981 New Member
    07 TRD Tundra 5.7
    Head unit, sub's , components, front / back camera's, too many lights to mention, dual battery, winch / bumper, TRS projector headlights, roof nest hard-shell, integrated backup spot lights, vault, all aluminum radiator / water pump, tailgate storage, plenty of dents and scratches
    You need to pull engine codes, step 1. AutoZone does it for free, a ~30$ Bluetooth OBDI is another step 1 to get started in all troubleshooting. :thumbsup:
    PhotoNerd likes this.
  3. Oct 16, 2024 at 12:11 PM
    Hilandr
    Hilandr New Member
    2011 Tundra SR5
    When this happened to me, it was because there was a short in my wheel speed sensor wire.
    My suggestion - test the speed sensor wire harness for continuity before buying/replacing the speed sensor. That's what I did, I found the tear in the jacket of the wire - re-spliced it back together and voila, no more issue.
  4. Oct 16, 2024 at 12:43 PM
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    That was going to be my guess, speed sensor
