4hi Transfer case actuator clicking 4wd does not engage
Discussion in '2nd Gen Tundras (2007-2013)' started by Ianstundra, Jun 18, 2021.
  1. Jun 18, 2021 at 3:55 PM
    Ianstundra
    Ianstundra [OP] New Member
    Ian
    When I try to engage 4hi, my 4hi flashes, I hear my actuator whirring then it beeps for a few seconds, then it clicks for a few seconds, then it starts whirring again and 4hi flashes quickly. Both 4hi and 4lo actuators are in perfect condition. When I had the 4hi actuator off, but still plugged in, I had my assistant turn on 4hi, then I manually pulled out the 4hi transfer case shift rod at which point the ADD actuator actuated and made a clunk. My diagnosis is that although my actuators are functional, the 4hi actuator is unable to pull the transfer case shift rod out. Has anyone had this problem or know a solution? Thanks.
  2. Jun 18, 2021 at 4:01 PM
    Ianstundra
    Ian
  3. Jun 18, 2021 at 4:03 PM
    Ianstundra
    Ian
  4. Jun 18, 2021 at 4:54 PM
    Ianstundra
    Ian
    After further inspection and alteration, the rod is moving, however the signal switch is not being pushed.
  5. Jun 25, 2021 at 12:38 PM
    mb66
    mb66 New Member
    Dr Doobie likes this.
  6. Jun 25, 2021 at 2:25 PM
    GatorBodine
    GatorBodine New Member
