4hi to 4lo..not in neutral..
Discussion in '2.5 Gen Tundras (2014-2021)' started by JackwagonJim, Jan 19, 2022.
  1. Jan 19, 2022 at 5:16 PM
    JackwagonJim
    JackwagonJim [OP] New Member
    Purlear, NC
    My better half took the truck (2020 pro) out for some errands today, amd for some reason took the unpaved road home...which was still covered in snow, ice, and slush.
    I havent yet explained how to shift into 4hi, etc...
    Any how, low and behold she got a little stuck in 2wd. She went 4 hi, and made progress, but started sliding in a ditch, so once she stopped moving, she went to 4 lo, but wasnt in neutral. She said the 4 lo light was flashing, no strange sounds happened. She made progress in movement so went 4 hi until she hit the paved section of road and went 2 hi.
    So my question..how bad is it to go 4hi to 4 lo without being in neutral? I have yet to even go in 4 lo, so not positive if that light is supposed to flash or not...
    The truck seems to be fine, and more importantly, she got home safely.
  2. Jan 19, 2022 at 5:23 PM
    AZBoatHauler
    So.Arizona
    It didn’t go to 4 low. The light flashing indicates an attempted shift. It goes solid when it shifts. She must not have mentioned the truck started screaming (beeping) at her when she attempted to shift to 4 low while not in N.
  3. Jan 19, 2022 at 5:25 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I don't think that the ECU will not allow a shift from 4hi to 4lo (nor back) without being in neutral. The light will flash and there will be an audible beeping (she may've just not noticed). I'm sure that your truck is fine. :thumbsup:
  4. Jan 19, 2022 at 5:29 PM
    JackwagonJim
    Purlear, NC
    Cool, thx fellas!
    Tundrag33, 2mchfun and AZBoatHauler like this.
  5. Jan 19, 2022 at 5:36 PM
    Schivie
    Schivie New Member
    2021 Red Tundra TRD Pro
    Westin running boards
    First and foremost I am glad she made it home safely. Lets face it, yes it would suck to damage the truck but it is replaceable.
    Leave it to me (I am Mr. RTFM old habit taught by my dad), park is ideal for the changing from 2 to 4H to 4L. If she did not hear the beeping it is not likely she made it to 4L.
    I agree that it is not likely she did any damage.
  6. Jan 19, 2022 at 5:46 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Unnecessarily takes the snow covered unpaved road home… she’s a keeper.
  7. Jan 20, 2022 at 4:04 AM
    blanchard7684
    blanchard7684 New Member
    nothing to add here...the system locks you out from going from 4hi to 4 lo without the vehicle speed and shift position feedback being correct.
    This is because the transfer case shift into 4 lo is unsynchronized.
    RainMan_PNW likes this.
  8. Jan 20, 2022 at 4:36 AM
    Cody1060
    Cody1060 New Member
    Ken
    Mid Michigan
    2021 Tundra 1794
    Totally agree! She's a keeper!
    joonbug[QUOTED] likes this.
  9. Jan 20, 2022 at 5:17 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    You have to be moving slightly to shift into 4Hi.
  10. Jan 20, 2022 at 6:00 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    4hi in park won’t do anything. You have to be moving. I shift in and out of 4hi all the time when the roads are snowy and shitty.
    Cpl_Punishment likes this.
  11. Jan 20, 2022 at 7:49 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Women always tend to leave the good stuff out.:rofl:
