4hi question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mat1018, Jan 16, 2024.
  1. Jan 16, 2024 at 5:19 PM
    Mat1018
    Mat1018 [OP] New Member
    Mat
    2016 Super White platinum CM 4x4
    4" lift, spyder headlights and tail lights, LT headers. Carven exhaust, and XD series monsters II wheels.
    So looking on where to start troubleshooting with 4hi.
    So issue is truck will not Disengage out of 4hi when driving, will shift into 4hi quick and easy. Same with 4lo no issues getting into, but coming out of 4hi when driving I can not get it to Disengage, I have to come to a stop and put it in either natural or reverse and it will pop out. Sometimes I can get it to Disengage when making a hard turn either left or right.
    I have tried being off the throttle, on the brakes, off the brakes, slow coast in neutral but nothing seems to help unless I stop.
    Not sure if it's a binding issue or an actuator issue but it use to shift in and out of 4 hi in the past with no issues. I've been under the truck when it's engaging and Disengaging and the transfer case actuator sounds normal but the front diff one is louder then the t case. No grinding or popping just loud electric motor sound.
    Also use it often, in either snow, sand or mud up here in the PNW. Never goes more the 2 month without being put into 4x4.
  2. Jan 16, 2024 at 7:25 PM
    koditten
    Kirk
    Midland of the Mitten
    Does it beep at you when you try to switch back to 2wd?
  3. Jan 16, 2024 at 7:34 PM
    Mat1018
    Mat
    Nope just flashes.
  4. Jan 16, 2024 at 7:36 PM
    Ever change the front diff and transfer case fluids?
  5. Jan 16, 2024 at 8:16 PM
    Mat1018
    Mat
    Yup did a fluid change front, rear, and t case around 40k
    At 53k right now.
  6. Jan 16, 2024 at 8:44 PM
    AZBoatHauler
    So.Arizona
    What transfer case fluid did you use?
  7. Jan 16, 2024 at 9:03 PM
    Mat1018
    Mat
  8. Jan 16, 2024 at 9:25 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
  9. Jan 16, 2024 at 9:25 PM
    AZBoatHauler
    So.Arizona
    Terndrerrr and OHwendTrd like this.
  10. Jan 16, 2024 at 10:10 PM
    Ct. Rich
    Ct. Rich New Member
    Maine
    2016 Limited TRD
    I’ve had great luck with Ravenol 75W in my 2016 transfer case. Even in this crazy cold weather, quick engage/disengage.
  11. Jan 17, 2024 at 4:09 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
  12. Jan 17, 2024 at 5:44 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    My first thought was wrong spec fluid. It wants that straight 75w. 75w90 is 3-4x as thick at operating temperature. The spec changed in 2014? when they when to a different transfer case.
    When I first got my LX, it would throw dash lights every time I tried to engage or disengage the center diff lock or low range. I changed the TC oil and started exercising both daily after driving my kids to school so the entire system was warmed up. Did that every day for a week, and it has had no problems since.
    yakeng likes this.
  13. Jan 17, 2024 at 6:59 AM
    bonefish
    bonefish New Member
    Peter
    Treasure Coast Florida
    Change out to 75W. 75-90 is too heavy for TC.
    MadMaxCanon likes this.
  14. Jan 17, 2024 at 8:37 AM
    Mat1018
    Mat
    I'll give the 75w oil a shot and see how that goes. Now just have to wait on shipping.
  15. Jan 17, 2024 at 10:30 AM
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    I used Ravenol 75W in my transfer case and now it shifts alot faster
    KNABORES likes this.
  16. Jan 17, 2024 at 11:18 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    I have a good friend that’s parts manager at a Toyota dealership. He said that the only time they use 75w is if it is a warranty issue. Otherwise it’s 75-90w. I called a couple other dealers service departments and asked for a price and what they use for fluid they told me 75-90 in tc, and front and rear. I change mine out and used 75-90 synthetic in them 20,000 miles ago and everything works as it should. Thought I would Pryor know my experience.
  17. Jan 30, 2024 at 4:31 PM
    Mat1018
    Mat
    So changed the fluid to 75w and still having the same issue. Did alittle more troubleshooting while driving. In park I can shift it into and out of 4hi without any issue. But once I start driving I can only get it to come out of 4hi if I turn the steering wheel about 270-360 degrees it will Disengage. So seems like probably a binding issue. But not sure how to exactly pin point it to that. Anyone have any ideas where to start or more troubleshooting ideas?
  18. Jan 30, 2024 at 4:52 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Have you looked at the differential or xfer case actuators?
  19. Jan 30, 2024 at 5:07 PM
    Mat1018
    Mat
    That's also my next thing to check out. Trying to decide if I want to pop them open and make sure they don't have dirt or corrosion in them. Or if I want to completely take them off to look them over.
