4HI on pavement
Discussion in '1st Gen Tundras (2000-2006)' started by LASurf, Feb 28, 2023.
  1. Feb 28, 2023 at 6:01 PM
    LASurf
    LASurf [OP] New Member
    Los Angeles
    300k+mi 06 AC4x4
    Found one today and have got a handshake deal with the seller. Current owner purchased from the original owner, his father in law. All checks out although he did mention putting the truck in 4HI whenever he drove in the rain. He's only had the truck for a couple years, and this is southern california we are talking, about. But is this any concern? There is a small amount of cv grease sling, but looks old. Thanks
    https://losangeles.craigslist.org/sfv/cto/d/agoura-hills-2005-toyota-tundra-limited/7594309562.html
  2. Feb 28, 2023 at 6:10 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    You're back!! Is this like your 4th 1st gen?
    Driving in 4Hi in the rain is not a big deal. I do the same thing to help lube the actuators.
  3. Feb 28, 2023 at 6:12 PM
    LASurf
    Los Angeles
    300k+mi 06 AC4x4
    Thanks. Haha it might be. What do you think of the find?
  4. Feb 28, 2023 at 6:12 PM
    shifty` All my rowdy friends have settled down
    I put on 4HI while driving in the rain on pavement all the time.
    It's not a problem as long as you're not making sharp turns. It's hot, dry pavement that's the killer. Wet roads will allow tires to slip as long as you're not turning more than 60deg or so.
    I wouldn't be concerned. I mean, no reason you can't play it up like there's concern. The PO would've definitely heard popping and felt bucking if they turned too sharply. But that would've likely only happened with sharp turns at slow speed on totally wet pavement.
    LASurf[OP] likes this.
  5. Feb 28, 2023 at 6:13 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Looks like the perfect truck for you to buy and then sell within a year.
    shifty` likes this.
  6. Feb 28, 2023 at 6:14 PM
    Oh - and it looks like a great find, and not just b/c it's a twin to mine. Other than the interior color (I'd have rather had tan) and the nerf bars (which I'd rather have - holler if you get it and get rid of 'em)
    Yep ^^
    After cleaning up that paint and other little bits, totally. The OEM bedliner is still available from Toyota Parts. I have the part #.
  7. Feb 28, 2023 at 6:15 PM
    LASurf
    Los Angeles
    300k+mi 06 AC4x4
    That's what I told my wife.
  8. Feb 28, 2023 at 6:18 PM
    LASurf
    Los Angeles
    300k+mi 06 AC4x4
    They are yours if I buy it. Thanks!
    shifty`[QUOTED] likes this.
  9. Feb 28, 2023 at 6:58 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    That’s called having shitty tires with no traction in the rain and having no lsd. I tossed it in 4wd going around corners in the rain sometimes on the stock Bridgestones. With Michelins
    LTX, that issue went away.
  10. Feb 28, 2023 at 10:18 PM
    Aerindel
    Aerindel New Member
    Montana
    I've driven tens of thousands of miles on the highway in 4WD....
    Its not a big deal.
  11. Mar 1, 2023 at 4:15 AM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    My t4r manual said 10 miles a month in 4wd in low traction driving to keep everything lubed and working. Every time I drive my tundra in the rain or off-road I switch to 4wd.
    shifty` likes this.
