4hi not disengaging? Icey roads.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Surfthetundra, Jan 10, 2016.
  1. Jan 10, 2016 at 5:18 AM
    Surfthetundra
    Surfthetundra [OP] New Member
    SouthEast US.
    2015 toyota tundra
    3" Toytec Lift, 20" Mayhem Wheels (8090) 34.1" Tires. More to come.
    so today I had to drive through ice. I parked in the parking lot before work. I tried to disengage the 4hi back to 2wd. It did not disengage. However I turned the knob to 4lo and it adjusted to 4lo. I turned the truck off and back on and it was in 2wd. Anyone have any answers?
  2. Jan 10, 2016 at 6:12 AM
    Jack Burton
    Jack Burton New Member
    Little China
    2013 DC 5.7L TRD/OR
    Tires, Diamondback HD Tonneau w/ ATV Carrier
    I'm not entirely sure what you're saying, but it sounds like you tried to shift from 4hi to 2wd while parked and it wouldn't go? If so, then you'd just need to be moving a bit for it to disengage. When you switched to 4lo then back to 2wd, it managed to get enough jiggering to disengage it is what it sounds like.
    csuviper and Surfthetundra[OP] like this.
  3. Jan 10, 2016 at 6:23 AM
    Surfthetundra
    SouthEast US.
    2015 toyota tundra
    Will it hurt anything if I'm say,, in neutral possibly drifting at .001 mph? Then switch?
  4. Jan 10, 2016 at 7:27 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Won't hurt anything. Just a little movement will help it disengage. You can disengage at highway speed if needed too.
    Surfthetundra[OP] likes this.
  5. Jan 10, 2016 at 7:42 AM
    Good practice is to "excercise" the actuator ...I think the manual calls for 10 miles a month. I usually drive a straight road a few miles a week (if I remember) in 4HI.
    4L I will drive a few seconds straight near my driveway...I seem to forget this one a lot. :anonymous:
