4HI Flashing
Discussion in '2.5 Gen Tundras (2014-2021)' started by DFWPlatinum, Apr 23, 2020.
  1. Apr 23, 2020 at 11:23 AM
    DFWPlatinum
    DFWPlatinum [OP] New Member
    Stephen
    2017 Tundra Platinum CrewMax
    6”RC lift on 35’s
    Just created an account and looked through a lot of the posts here. I have a 2017 Tundra Platinum and my 4HI just continually flashes and 4LO gives me the tone and flashing light. I’ve tried all the tricks of full turn engagement, backing up, trying it over and over again to just get it to unstick. I can feel the rpm’s rise slightly like the truck is trying to engage 4HI but it won’t lock the front diff. Any change anyone’s had this issue or found the solution.
  2. Apr 23, 2020 at 5:30 PM
    _SP_
    _SP_ New Member
    Shawn
    2014 1794 Edition
    de-chromed
    did it ever work? are you the original owner? I had a NIGHTMARE with a similar issue when my truck was new with less than 100 miles on it. I have a long post on another forum if im allowed to post here. Ill try in a sec. Let me see if I can dig it up.
  3. Apr 23, 2020 at 5:39 PM
    SMK Shoe
    SMK Shoe Not New Member
    Paul
    Central North Carolina
    2017 Tundra TRD DC
    Step Bars, Rear Swaybar, 2,000 Watt Amp, 2-10" Subs, new door speakers, De-Badged, Hondo vent mounts, Calipers, 6112/5100 shocks, SPC UCA's, Front bumper, Bed Bars, bed rack, Fuel Rims
    Get in the owners manual. I have the same year and after using 4 low on the property for the afternoon couldn't get it to go back to 2 WD. I was just not doing the steps in the correct order. Was a simple solution when I did it the right way.
  4. Apr 23, 2020 at 5:40 PM
    _SP_
    _SP_ New Member
    Shawn
    2014 1794 Edition
    de-chromed
    here is my post from 2014
    https://www.tundratalk.net/threads/...ur-truck-to-disengage-from-4wd-to-2wd.419729/
  5. Apr 23, 2020 at 6:48 PM
    DFWPlatinum
    Stephen
    6”RC lift on 35’s
    No changes, the truck is in 2WD and will not engage 4WD. When switched to 4HI the light just flashes (the correct sequence was done), when attempting 4LO(correct sequence used) I get the flashing symbol and the tones indicating it is not engaging.
  6. Apr 23, 2020 at 6:56 PM
    Check the actuator?
  7. Apr 23, 2020 at 7:04 PM
    DFWPlatinum
    Stephen
    6”RC lift on 35’s
    Actuator is good
  8. Apr 24, 2020 at 4:10 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Fluid in t-case or actuator in-op...dealership-time....man, that's a lot of hyphens!
  9. Apr 24, 2020 at 6:38 AM
    DFWPlatinum
    Stephen
    6”RC lift on 35’s
    Yeah, I’ve got an appointment today. I’ll let you guys know what they say.
