4hi flashing
Discussion in '2.5 Gen Tundras (2014-2021)' started by 92lt, Sep 8, 2025 at 5:52 PM.
  1. Sep 8, 2025 at 5:52 PM
    92lt
    92lt [OP] New Member
    Western NY
    2016 Tundra Black LTD
    2016 tundra. If I switch to 4x4 it goes into 4x4 but 4hi flashes. If I turn off the truck while in 4hi then back on the 4hi stays lit and doesn't flash. Any ideas what is cause?
  2. Sep 8, 2025 at 5:56 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Probably one of your actuators. I've replaced my diff actuator twice. The flashing indicates trouble shifting into 4WD, but if it stays lit the front diff is engaged.
    bulldog93 and OldGuy03 like this.
  3. Sep 8, 2025 at 5:58 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Or a wheel bearing.
    Check the wheel speed sensor. And run a scan tool. That will tell you which bearing if that's the issue.
    texasrho83 likes this.
  4. Sep 8, 2025 at 6:09 PM
    92lt
    Western NY
    I should have mentioned the truck sat for last 2 years unused. It has ultra low miles on it. Would wheel sensor throw a code? Cause it's not showing any codes
  5. Sep 8, 2025 at 6:10 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    That has bad actuator written all over it
  6. Sep 8, 2025 at 6:28 PM
    92lt
    Western NY
    But I know it is physically going in/out of 4x4. I feel the engagement and tested on gravel incline.
    Could it be the diff actuator even if 4x4 is physically working?
  7. Sep 8, 2025 at 6:29 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yes, intermittent issues are common right up until it quits working altogether.
    OldGuy03 likes this.
  8. Sep 8, 2025 at 6:38 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Agreed now knowing it sat for that long. Actuators need monthly usage.
  9. Sep 9, 2025 at 11:47 AM
    92lt
    Western NY
    ok. You guys are right. Front add is not engaging. Its interesting cause i can shift the transfer case into 4hi and 4low. Couple questions...Is there an add relay or fuse? Would I hear if the front add actuator was attempting to engage (similar to how i hear the tcase actuator)?
    Thanks for all help.
