4hi 4lo flashing - Traction Control and ABS solid
Discussion in '2.5 Gen Tundras (2014-2021)' started by Joemomma03264, Dec 26, 2023.
  1. Dec 26, 2023 at 7:27 AM
    Joemomma03264
    Joemomma03264 [OP] New Member
    Gabe
    2015 Tundra Platinum
    I have a 15 tundra platinum. This summer the truck got stuck in mud and the 4x4 wouldn't engage. For about a month after that the 4hi 4lo lights would sporadically start flashing. When flashing the 4x4 was inoperable. After about a month the lights flashed constantly.
    First I replaced ABS/Speed sensors, no change. Then I replaced hub assemblies, no change. Then I replaced axle wiring harness, no change. I then replaced complete axle assemblies, still no change.
    My buddies scan tool comes up with LR speed sensor circuit open. No continuity to abs wiring under hood...
    Codes are C1333 and C1241
  2. Dec 26, 2023 at 9:35 AM
    Did you check the speed sensors by the wheels? Those wires are thin.
  3. Dec 26, 2023 at 9:44 AM
    Surely more to the getting stuck story than your letting on. Replacing entire axles and harnesses for a wheel speed fault code seems extreme.
  4. Dec 26, 2023 at 12:06 PM
    Joemomma03264
    Gabe
    Yes, the first thing I did was replace those sensors.
  5. Dec 26, 2023 at 12:09 PM
    Joemomma03264
    Gabe
    Not much more to tell. I was driving across my front lawn, not realizing how soft it was. I started to spin which immediately dug a hole. I then tried to put in 4x4 with no luck..
  6. Dec 27, 2023 at 4:35 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    You replaced your hubs and entire axle assemblies blindly to chase a light??
  7. Dec 27, 2023 at 6:35 AM
    Joemomma03264
    Gabe
    I did. No one can seem to figure this out and now I'm driving it uninspected. Trying to get it resolved before I get a ticket.
  8. Dec 27, 2023 at 7:10 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I'm guessing that the ticket would have been a lot cheaper than new axles. Are you having a shop or dealer working on it?
  9. Dec 27, 2023 at 11:15 AM
    Joemomma03264
    Gabe
    Complete Axles from Dorman aren't much more $ than those sensors were.
    It's been to 3 different shops. I was trying to avoid the stealership but it's looking like that's the route I'll have to go.
  10. Dec 27, 2023 at 11:23 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Ah gotcha. Yeah it's sounding like it's going to have to be a dealership since it's turning into a mouse hunt.
    On the positive side, you have new axles lol
