4H Mode
Discussion in '3rd Gen Tundras (2022+)' started by LimitedFL, Mar 11, 2023.
  1. Mar 11, 2023 at 10:19 AM
    LimitedFL
    LimitedFL [OP] New Member
    Kal
    2023 Limited
    First time owning a 4x4.
    When I have the truck in 4H and backing into a parking space, it feels like I have parking brake on. Applied more gas the engine revved but it barely moved. This happened when the steering wheel turned about 360 degree. If the steering wheel slightly turned, it backing up fine.
    Is this normal?
  2. Mar 11, 2023 at 10:22 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    If you're in a high traction scenario, yes. Your driveline is binding, you want to avoid this.
    raylo and Yaboy like this.
  3. Mar 11, 2023 at 10:23 AM
    WhiteTundra0013
    WhiteTundra0013 New Member
    2013 white tundra
    Trd rear sway bar, Rims, Goodyear wrangler tires,Topper, Nerf bars
    You should only use 4wd in rain or snow,mud, if you use it on dry pavement you will get a jerky movement and you could damage your drivetrain if you make sudden sharp turns.
    Caveman likes this.
  4. Mar 11, 2023 at 10:29 AM
    You can use it on straight lines, (on dry pavement) and Toyota recommends 10 miles per month of 4WD to keep it lubed up
    raylo and ryanwgregg like this.
  5. Mar 11, 2023 at 10:45 AM
    KingsAustin
    KingsAustin Grey Goose II
    Morgan County, AL
    2021 Limited Night Shade
    BakFlip MX4, Gator All Weather mats, Console Safe, Ceramic Tint, Roadmaster Active Suspension, Interior/exterior LED conversion, Wireless console charger, AJT designs.
    This happens to me when in rain/snow only because I am old and forget to turn the 4x4 off before I get off the straight roadway.
  6. Mar 11, 2023 at 11:30 AM
    LimitedFL
    Kal
    2023 Limited
    I thought 2H & 4H were basically the same; it was just 2- or 4-wheel in operation. I was about to bring the truck in for diagnostic.
    Thanks everyone for the input.
    Henry1jg likes this.
  7. Mar 11, 2023 at 11:42 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    LimitedFL[OP] and eastbaysteve like this.
  8. Mar 13, 2023 at 4:16 AM
    nodak67
    nodak67 New Member
    JR
    you would think a first time 4wd buyer would at least read the owners manual of a 4x4 system. i mean there is a whole lot of pages dedicated to the 4x4 system.
    4genRunner and Mattedfred like this.
  9. Mar 13, 2023 at 7:38 AM
    LimitedFL
    Kal
    2023 Limited
    Couldn't agree more :). A few years ago, I was with a friend in his 4x4 showing how smooth it was switch from 2H to 4H while under 30mph. So I ASSumed 4H was just all 4 wheels powered. Thought I could do the 10miles as recommended while out running errands.
