4H 4L lights blinking in dashboard
Discussion in '3rd Gen Tundras (2022+)' started by Fortoyo, Nov 13, 2022.
  1. Nov 13, 2022 at 7:46 AM
    Fortoyo
    Fortoyo [OP] New Member
    Does anyone had observed that the "4H" "4L" lights gone blinking in yellow after shifting from "2H" to "4H" and turning the steering all the way to the right?
  2. Nov 13, 2022 at 7:51 AM
    Boats N TRDs
    Boats N TRDs New Member
    Travis
    2022 Tundra Limited HV TRD OR
    Chrome delete
    It blinks while it's trying to engage the transfer case. Drive straight until it fully engages.
    Yaboy likes this.
  3. Nov 13, 2022 at 9:23 AM
    MDesi
    MDesi New Member
    Matthew
    22 TRD Pro
    This happened to me. I believe I was in reverse when it happened. It wouldn’t go into 4WD. I had to shut the truck off. I then got a notification to take it to a Toyota dealer for some error associated with the drive train. After restarting it worked fine. I think my issue was putting in 4WD while in reverse. I haven’t tried to recreate the issue
  4. Nov 13, 2022 at 9:39 PM
    Fortoyo
    My concern was that the "4H" "4L" lights went blinking while riding in "4H" for a while, after making a turn with the steering wheel completely to the right. In my particular situation, Toyota did not approved any guarantee in the axles because they claim that my suspension system is modified because of installing a Ready Lift 3-inch SST. So I am afraid of a very uphill struggle for claiming an evaluation of problems in the differential.
  5. Nov 14, 2022 at 12:24 AM
    GIN•OKUMA
    GIN•OKUMA Can’t get to SSEM from there. RGBA1
    Fish
    26.57°
    Noun; a machine, usually with wheels and an engine, used for transporting people or goods, especially on land
    Probably not a great idea to turn the wheel all the way to one side or the other when engaged in 4wd. Especially if you’re not in a situation like snow, mud or sand.
  6. Dec 29, 2022 at 9:42 AM
    Insulator
    Insulator New Member
    2023 CMLB Lim TRD / 03 Tundra Lim AC
    Dual Battery
    I had blinking lights same as the OP, but for a different reason. 2023 CrewMax 6.5’ bed Limited TRD OR. I switched into 4H and after 30s the 4H and 4L lights started flashing and got a “call the dealer” message that would not go away. I turned off the truck once I got where I was going and restarted it. Lights were off and truck switched into 4H just fine.
    My suspicion is that I drove the night before in warm slushy snow and it dropped to 25 overnight. Before the truck really warmed up, some mechanical switch was still frozen enough that it wouldn’t actuate until the truck was more warmed up.
    Long story short, I won’t be going to the dealer if this happens again (just turn it off and on again) and I’m annoyed that it won’t reset while the car is running… I can’t exactly power off the car just to reset some flashing lights. Coming from a 2003 Tundra, that truck would flash lights if the 4wd didn’t successfully engage, but you’d put the switch back to 2wd and wait a sec and try again and it would be fine. This one screams like a child that stubbed their toe and thinks they need to go to the hospital.
    The message “call your dealer” adds insult to injury. I don’t trust my dealer to be able to inspect it without doing more damage while taking something apart to inspect it.
