$40 for a gallon of coolant, $25 for a QUART of ATF is this for real??
Discussion in '1st Gen Tundras (2000-2006)' started by WaterOp, Apr 11, 2024.
  1. Apr 11, 2024 at 8:33 AM
    WaterOp
    WaterOp [OP] New Member
    So Lake Tahoe, CA
    2005 Tundra Access V-8 Auto 4x4
    Admittedly I'm an old guy, but just went to my local Carson City NV dealership for some longlife (100%) coolant ($40/gallon). :spending:
    I also priced ATF ($25/quart) because I'd like to do a fluid change on the trany, maybe 12-13 quarts so $350 with tax, just for trany fluid?? :annoyed:
    I was shocked at the prices and wanted to check with you guys as to if these are normal?
    I'm leery of purchasing anything from Amazon these days as there have been so many reports of fake stuff. Any suggestions on other options to purchase Coolant or ATF a bit cheaper?
  2. Apr 11, 2024 at 8:38 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
  3. Apr 11, 2024 at 9:16 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    2003 V8 SR5, Access Cab, 4x4, White
    As far as the coolant goes, it's undiluted. So, theoretically you're buying 2 gallons. Assuming you have the V8, you'll need somewhere between 2-3 gallons. Manual says 12.3 quarts. When I did my timing belt and water pump I think I put in 2 1/2 ish gallons. The manual also states "Toyota Genuine Long Life Coolant" or equivalent. I used Zerex Asian vehicle 50/50 formula. That will save you some $.
    As far as the ATF goes, not sure where you're getting 12-13 quarts. A drain and fill is only going to require UP TO 2.1 quarts, and a full change is not necessarily recommended unless you're driving under "Special Operating Conditions" which means you're towing A LOT. I also think you could get away with a different brand of ATF, as long as it's Type T-IV.
  4. Apr 11, 2024 at 9:24 AM
    2mchfun
    Paid about $30 ish/gal and about $8 ish/qt in OKC about 6 months back. Still a rip off IMO, so yeah, you are getting taken for a ride.
  5. Apr 11, 2024 at 3:10 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I don't buy Toyota fluids for that exact reason. Zerex Asian coolant and Valvoline maxlife ATF (gasp I know), but I've had really good luck with it in 4 toyotas that "require" WS ATF.
    Okiebug, koditten, JakeJake and 5 others like this.
  6. Apr 11, 2024 at 3:31 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    $25/quart sounds like a bargain compared to the $40/quart used in the RAM tranny. As others have said, find an equivalent make from another manufacturer.
    ATBAV8 likes this.
  7. Apr 11, 2024 at 4:49 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    We all know Toyota doesn't have their own refineries and coolant facilities. They buy from Global manufacturers and re-package it with the Toyota name on the bottle. Bonus points to whomever finds out who makes Toyota ATF and coolant.
  8. Apr 11, 2024 at 5:08 PM
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    I met a buddy out last night. 18 wings and a short beer was $50. Everything is stupid expensive!
    1lowlife and 2mchfun like this.
  9. Apr 11, 2024 at 5:12 PM
    shifty` In South Dakota Trouble ain't hard to find
    I had no choice but to eat at 5 Guys on Tuesday. Little bacon cheeseburger, small fries, small drink set me back $22. Absurd.
  10. Apr 11, 2024 at 5:55 PM
    TexasGuyTX
    TexasGuyTX New Member
    Ryan
    2007 SR5 Super White
    PRO BOX w/ RF Mono Amp Limited 20" Wheels HID's on Low Beams Tip Delete Before Axle
    eating at the house like a king
    Rsmallw2 likes this.
  11. Apr 11, 2024 at 5:59 PM
    FrenchToasty
    Mo
    Bone stock
    Don’t take your family to McDowells
    OldGuy03 and shifty`[QUOTED] like this.
  12. Apr 11, 2024 at 6:01 PM
    1lowlife, OldGuy03, WFD473 and 2 others like this.
  13. Apr 11, 2024 at 6:03 PM
    Jack McCarthy
    Bill
    North of Boston
    Most of my lunches that are unprepared ahead of time are bought at Market Basket for $6-$9/each.
    FrenchToasty likes this.
  14. Apr 11, 2024 at 6:27 PM
    koditten
    Kirk
    Midland of the Mitten
    I'm not a fan of transmission flushes.
    Just drain and fill. Takes about 4.5 qts to replace what you drained out of the pan.
    I do drain and fills every other year. I do a lot of towing, so this gives me comfort.
    I use Asian equivalent coolant as well. Whatever is on sale.
    1lowlife, Mdl and ATBAV8 like this.
  15. Apr 11, 2024 at 7:07 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    Thanks. Did not know.
    ryanwgregg[QUOTED] likes this.
  16. Apr 11, 2024 at 8:45 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    No you are buying 1 gallon of antifreeze...you sound like them Charmin people18 jumbo rolls equals 30 regular rolls....wtf? LOl
  17. Apr 12, 2024 at 7:58 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    It's undiluted. 50/50 dilution ratio=2 gallons. Math much? WTF?
  18. Apr 12, 2024 at 11:03 AM
    Roborob70
    Robert
    Ever since I have been a little kid antifreeze has been sold in gallon jugs, then somewhere along the way about mid 90's someone decided to start selling it diluted, then everybody started selling it diluted. If a gallon jug of antifreeze is undiluted it is one gallon not two. It becomes two gallons when you add you add water. If undiluted he is only paying for antifreeze and not water, which is the smart thing to do. Why is this so difficult?
    Dook55 likes this.
  19. Apr 12, 2024 at 12:07 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    Geezus. Way to get wrapped around the axle in semantics. Do you use coolant diluted or undiluted? I rest my case.
  20. Apr 12, 2024 at 12:13 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    Zerex Asian Vehicle Red Silicate and Borate Free 50/50 Prediluted Ready-to-Use Antifreeze/Coolant 1 GA (Pack of 2)
    Brand: Zerex
    2 ratings
    | Search this page
    Bundle List Price: $39.98$39.98 Details
    Bundle Price: $36.24$36.24 One-DayFREE Returns
    You Save: $3.74$3.74 (9%)
    Same price. $20/gallon diluted vs. $40/gallon undiluted.
