4" or 6" lift and are adjustable struts/shocks worth the money?
Discussion in 'Suspension' started by Hibby, Mar 11, 2022.
  1. Mar 11, 2022 at 9:39 AM
    Hibby
    Hibby [OP] New Member
    16' Tundra
    2016 crew max limited, but stock 2021 tundra black 20s and 35x12.50 Ridge grapplers. Debating 4 or 6in lift, can get them installed same price. Also adjustable struts/shocks or are they even worth the money
  2. Mar 11, 2022 at 9:40 AM
    And the question is?
  3. Mar 11, 2022 at 9:41 AM
    Hibby
    16' Tundra
    Would i have the clearance on 4" or go 6, and are adjustables worth the money
  4. Mar 11, 2022 at 9:48 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    You can fit 35s with 2-3 inch lift and proper offset wheels. No need to go higher unless you just like that.
  5. Mar 11, 2022 at 9:55 AM
    cementsharktrd
    cementsharktrd New Member
    Demetrio
    2021 Cement Tundra TRD Off-Road
    7 inch bds coilover lift kit
    i say 4inch. I wish i didn't go so high on mine!
  6. Mar 11, 2022 at 10:13 AM
    Hibby
    16' Tundra
    Was debating vector gas adjustables or just lift struts and shocks? Your thoughts
  7. Mar 11, 2022 at 10:15 AM
    Hibby
    16' Tundra
    Thanks, i have the stock 2021 black 20s, i just dont wanna rub or chop/cut anything.
  8. Mar 11, 2022 at 10:23 AM
    frichco228
    If you plan on running 35s, depending on wheel offset, you may need BMC and some adjustments to the plastics, wheel liners, flaps.
  9. Mar 11, 2022 at 10:40 AM
    Hibby
    16' Tundra
    With the 4in?
