4 HI ques
Discussion in '2.5 Gen Tundras (2014-2021)' started by RookieEP, Feb 16, 2021.
  1. Feb 16, 2021 at 11:19 AM
    RookieEP
    RookieEP [OP] New Member
    2020 Tundra Limited TRD Magnetic Gray
    None
    2020 CM limited owner. First time with a true 4x4 system had awd SUVs prior. Loving my truck. My question RE 4HI. The scenario: lots of snow out. Leave my driveway turn on 4HI enjoying my commute without worrying about sliding all over the dang place. Truck been rock solid in the snow crap. I get to work approach my parking spot park far away from all the dang door dingers.. Do you turn the 4HI off prior to parking? Once parked? Or leave it on as I will be driving home in 4HI? Last question, this weekend I was on a 2 lane country hwy, there was long stretches of snow/ice and then no snow- one spot I was in 2wd and was going a curve hill that was now icey tires slipped some so turned on 4HI- do you have to wait for the tires to not slip/slide lay off the gas prior to engaging the 4HI or you can turn it on at free will
  2. Feb 16, 2021 at 11:22 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Leave it in 4WD when you park. Some guys live where you leave it in 4WD for months.
    While on the roadway twist the knob to go into 4WD HI when you want. Ya don't need a particular condition (other than don't be going 90 mph) to flip-the-switch.
    Leo's first and snivilous like this.
  3. Feb 16, 2021 at 11:28 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    If the road has varying spots of dry and snowy/wet you don't need to keep switching it into 2WD. Where 4WD is unhappy is going slow in a tight circle on a dry road, if you're driving down the road (even if it's super curvy), your tires are going to slip even if it's totally dry out. If there's varying snow conditions (or anything low traction) I just leave it in 4Hi until the road is totally clear and then go back to 2WD. The truck isn't going to break just because you leave 4WD on on dry ground.
  4. Feb 16, 2021 at 11:52 AM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    in all of those conditions you described i would just leave in in 4HI. won't hurt a thing. just don't do any tight slow turns with it on unless you're on slippery surfaces.
  5. Feb 16, 2021 at 12:02 PM
    RookieEP
    None
    Thanks everyone
