4.7 towing
Discussion in 'Towing & Hauling' started by quzytt, Jan 1, 2017.
  1. Jan 1, 2017 at 9:43 AM
    quzytt
    quzytt [OP] New Member
    I am considering buying a 2008 4.7 Tundra with the tow package. Will be pulling a 3500 lb camper. And hauling about 700 lbs in the truck. Am I going to be ok? Would appreciate your feedback.
  2. Jan 1, 2017 at 9:55 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
  3. Jan 1, 2017 at 10:26 AM
    Welcome to the forum.
    Is the 700 lbs including passengers?
    Towing mountains?
    276 hp is ok, but have 381 hp is where I would want to be.
    Other issues is the 4.7L has timing belt maintenance.
    Law323 likes this.
  4. Jan 1, 2017 at 10:32 AM
    George14
    George14 New Member
    West Virginia
    2014 Tundra SR5 Dc TRD Off Road 5.7L with tow package
    None
    I would go with the 5.7 not much difference in gas mileage
    Law323 likes this.
  5. Jan 1, 2017 at 10:38 AM
    quzytt
    Passengers would add about 300 lbs. Mountains......not the Rockies but the Smoky Mountains.
  6. Jan 1, 2017 at 10:57 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Go with the 5.7
  7. Jan 1, 2017 at 12:10 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    You'd be just fine if you aren't going through the mountains. That'll be about 5k lbs. tow package is a must with that weight and engine. Honestly though, I'd go with a 5.7 just for peace of mind.
    i towed about 4K - 5k between Baton Rouge and Memphis a few times with no problems. That's very small grades and mostly flat roads. I wouldn't want to hit the mountains with that weight.
  8. Jan 1, 2017 at 12:41 PM
    I thought you had the 4.6L Law....which has better numbers than the 4.7L for sure.
  9. Jan 1, 2017 at 12:46 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I do. And it did great towing 5K. Barely knew it was back there but still wouldn't want to hit the mountains with that weight. Of course I have bigger and heavier tires than stock. (Went from a 31 P rated highway tire to a 33 LT all terrain tire)
    I'm betting if I still had stockies, I wouldn't have any problems going through mountains.
