4.7 Engine swap computer problem
Discussion in '1st Gen Tundras (2000-2006)' started by medwards, Aug 22, 2019.
  1. Aug 22, 2019 at 9:30 PM
    medwards
    medwards [OP] New Member
    mark
    01 tundra trd 4x4
    Help! I just installed an 04 4.7 into my 01. Start up was very rough Computer threw all kinds of codes. Now mechanic says its not compatible and requires new computer and wiring harness. Im guessing its a vvt engine but not sure. Does anyone know how to get this working?
  2. Aug 22, 2019 at 9:32 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Welcome from CO!
  3. Aug 22, 2019 at 10:03 PM
    Aerindel
    Aerindel New Member
    Montana
    No experience with this problem on this vehicle.
    As I understand it, VVT was not available until 2005
    But in general, with engine swaps, if you keep the same intake and cam/crank position sensors you can swap engines okay even if not the exact same engine as most sensor and ECU stuff is intake related.
  4. Aug 23, 2019 at 4:52 AM
    medwards
    mark
    01 tundra trd 4x4
    Thank you for the responce. This is an 04 according to vin from the wrecked truck i pulled it from. Running fine w 150k. The heads are slightly different and the throttle body a little different. Other than that its same. We put the old throttle body on it and used all the 01 sensores and wiring. I put a full timing belt kit, plugs, serpentine belt on it. Double checked belt positiion. My mechanic is certified toyota and never had this problem. Called all his connections and was told it wont work. They apparently put 2 model 4.7 engines in 04. I researched this heavily before buying the engine and found no info saying this. Is there a way to find out by some other id on the block perhaps? We are both stumped
  5. Aug 23, 2019 at 4:57 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    What codes is it giving you?
  6. Aug 23, 2019 at 6:08 AM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    A lot of the shops will get used engines from overseas like Japan, were they have different emission set up. Also the US has 48 spec, California spec, Fed spec. The vehicle may or may not have knock sensors, O2 vs air fuel ratio sensors etc. So if your engines don’t match, the truck’s computer will throw codes. Example I had a Toyota Camry with two knock sensors, the overseas engine had none. It had no place in the block to screw in the knock sensors. The tech did not realize this until the engine install was 90% complete. So the tech wire tied them to the frame and the customer came back with the check engine light on. Not a happy camper!!!
    MS22 and Darkness like this.
  7. Aug 23, 2019 at 6:39 AM
    medwards
    mark
    01 tundra trd 4x4
    Us old farts have to stick together. I was a no computer carb guy til this tundra. 17 yrs never a problem. Always a computer problem these days. I think its a plot.
    This came out of a us model. I researched the vin. A toyota tech said it was a second generation 4.7. from the vin. Just hoping a computer guru will appear and know what to do. Everything plugs in exactly but so far 8 different codes have randomly popped up and engine dies
    Ajkkane and Luckydog like this.
  8. Aug 23, 2019 at 6:56 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    01 is cable throttle, 04 is drive by wire. Assuming you've gotten past that I can't think of too many differences. What codes is it throwing?
    speedtre likes this.
  9. Aug 23, 2019 at 7:29 AM
    medwards
    mark
    01 tundra trd 4x4
    Hei Luis, Thanks for the response.
    P0 135, 141, 155, 161, 758, 773
    P1120, 1126, 1760
    All these codes at different reboots
    We changed intake and throttle body to the old 01 btw
    It had the metal intake but different throttle
  10. Aug 23, 2019 at 5:51 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Sounds like the O2's, TB, and trans are having issues.
  11. Aug 26, 2019 at 10:29 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Maybe swap the ECU with the 04?
    Filthyphil likes this.
  12. May 18, 2021 at 6:53 PM
    Eddiejr1
    Eddiejr1 New Member
    Eddie
    01 tundra v8 limited
    I need help. I've been fighting my 01 tundra v8 for a year now. I put a new motor in it. Then noticed the throttle bodys were different I then I gotta 04 motor. I've but the older throttle body back on and the intake. But it's running like a@@ no power. And my pedal won't work till almost till the end I've got new sensors and a use throttle body and still the same. Can you help.
    Matix363 likes this.
  13. May 18, 2021 at 6:58 PM
    Eddiejr1
    Eddiejr1 New Member
    Eddie
    [QUOTE="did you ever fix the problem
  14. Jun 10, 2024 at 6:57 AM
    USERidiculousNAME
    USERidiculousNAME ToyTurd
    Josh
    New Orleans
    250K on Early 2004 tundra DC 4.7 v8, SR5, RWD, A/T, LSD, w/ABS,TOW, OFF ROAD, ZERO RUST FRAME, BILSTIEN 5100, AAL, 17" 265/70
    Backup camera, camper shell, double din stereo, amp, sub, blind spot cameras, modest lift, newer Tacoma rims, large AT tires, interior lighting upgrades, in bed, under hood, as well as leds in cab, blue foot well strips (night driving)or bright white strips if need to see, 3 additional white leds on ceiling front L/ R and center, toggle switch's and added accessory fuse box.
    Note to others reading this in the future. In August of 2004 the engine changed I believe that's when vvt started, if it wasn't vvt it was something else drastic
  15. Jun 10, 2024 at 7:08 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Easiest way to confirm whether you have VVTi or not is to look at your intake manifold. Non-VVTi have a cast aluminum intake manifold, and VVTi have a plastic intake manifold. 4.7s with a 5-speed auto transmission will be VVTi, and 4.7s with a 4-speed do not have VVTi.
    Production in August 2004 does not necessarily equal a 2004 model year Tundra either.
    metalpete likes this.
  16. Jun 10, 2024 at 7:25 AM
    You need to change your profile description, or show us the glorious pics of your 2004 Tundra with the 5.7 swap.
