4.6 v8 water pump life expectancy
Discussion in '2.5 Gen Tundras (2014-2021)' started by BarcelonaRedTundra, Sep 28, 2022.
  1. Sep 28, 2022 at 7:25 AM
    BarcelonaRedTundra
    BarcelonaRedTundra [OP] New Member
    Hi folks,
    New Tundra owner, 2017 4.6 V8 with 43,000 miles.
    Looking online there are several threads about the water pump on these motors only lasting about 60,000 miles.
    Wondering if this is the case, and if I should prepare to replace mine and what kind of life others have gotten from theirs.
    Thanks
  2. Sep 28, 2022 at 7:26 AM
    My 2013 with the 4.6 had 98,000 when I sold it and no issues at all.
  3. Sep 28, 2022 at 7:43 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I would not replace it unless it needed to be replaced. 2017 truck with 40k miles should not need that to be replaced for a long time.
  4. Sep 28, 2022 at 9:14 AM
    Tundra Dude 45
    Tundra Dude 45 New Member
    Eric
    2019 SR 4.6L DC 4X4
    8” BAMuffler, TRD airflow accelerator, front window tint/windshield sun stripe, debadged tailgate 4x4 emblem, trimmed mud flaps, antenna removed stainless screw added, TRD rear sway bar, AFE high flow air filter.
    I have a ‘19 with the 4.6L, I’m at 63,000 miles, no water pump issues. I didn’t know about this issue until now. How do I know if it goes bad?
  5. Sep 28, 2022 at 9:30 AM
    BarcelonaRedTundra
    I believe there will be weeping around the pump, eventually becoming a noticeable leak.
  6. Sep 28, 2022 at 9:47 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Bingo
  7. Aug 12, 2023 at 11:06 AM
    EmergencyMaximum
    EmergencyMaximum New Member
    Hi gang, 136k with original pump. Should I be worried? 2010 4.6l
    Oops sorry wrong gen, eh...
  8. Aug 12, 2023 at 9:45 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Is it oriental because its made in Japan?
    GODZILLA and WILLINH like this.
  9. Aug 12, 2023 at 10:00 PM
    EmergencyMaximum
    Original pump
  10. Aug 12, 2023 at 10:03 PM
    Joe333x
    Joe333x Member
    Boston
    Joke
  11. Aug 13, 2023 at 5:50 AM
    EmergencyMaximum
    Ok
  12. Aug 13, 2023 at 6:47 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    My original lasted 25k before it exploded and replaced under warranty with Toyota. My second one lasted about 200k before it exploded. If it's not leaking leave it alone.
  13. Aug 13, 2023 at 7:32 AM
    EmergencyMaximum
    Thank you, gang!:hattip:
  14. Aug 13, 2024 at 3:00 AM
    Fasteddie$
    Fasteddie$ New Member
    Eddie
    2010 Toyota tundra
  15. Aug 13, 2024 at 3:04 AM
    Fasteddie$
    Eddie
    2010 Toyota tundra
    I have a 2010 Toyota tundra 4.6 with tow package. Mine water pump started leaking at the weep hole, but bearings were excellent? The trans cooler may change life expectancy. But I just changed mine at 147k miles. Went oem pump and 2 gallons of Toyota antifreeze.$180 for parts. And $850 at local garage for the install.
