4-6 in lift
Discussion in 'Suspension' started by Javy, Mar 19, 2014.
  1. Mar 19, 2014 at 4:53 AM
    Javy
    Javy [OP] New Member
    2012 Toyota Tundra Texas Edition 4X4
    Nothing yet ?
    I'm thinking if doing a 4-6in lift with either rough country or ready lift . Are these good brands to use or should I go with something . What products has everyone else used and how much do they run ? Any input would be helpful thanks .
  2. Mar 19, 2014 at 7:34 AM
    I've read some good things about 'Ready Lift' but I ultimately decided to stick with a 3" OME lift as it's known for its durability.
    Law323 likes this.
  3. Mar 19, 2014 at 8:43 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Rough country offers a 4.5" and a 6" lift. They are drop bracket lifts with new cross members, spindles and blocks for your stock front shocks/coils. These lifts will be stiff without a replacement of the front shocks/coils with new extended length coil-overs.
    Readylift offers a 4" using new upper control arms and blocks for your stock front shocks/coils. This lift will also be stiff without a replacement of the front shocks/coils with new extended length coil-overs.
    Law323 likes this.
  4. Mar 19, 2014 at 7:30 PM
    Javy
    Nothing yet ?
    What size of lift do I need to fit 35's
    Can I get away with doing leveling kit for that
  5. Mar 19, 2014 at 8:31 PM
    JonasSacredTundra
    JonasSacredTundra New Member
    Depends on your offset, if you want stance 35s will rub more than likely on a 2.5 or 3. If you dont want stance you can definitely squeeze 35s on a 3.
  6. Mar 19, 2014 at 8:38 PM
    csuviper
    Broomfield, CO
    With my RW wheels I fit 315/70R17 (~35x12.5) Duratracs without rubbing on a 3" lift.
  7. Mar 19, 2014 at 8:57 PM
    Javy
    Nothing yet ?
    I have the 20 in that came with Texas edition package. And I would be putting Nitto trail grappler 35 x 12.5. I'm getting a smoking deal on tires but don't wanna rub
  8. Mar 19, 2014 at 8:58 PM
    Javy
    Nothing yet ?
    Csuviper did you have to do any modifications
  9. Mar 19, 2014 at 9:27 PM
    csuviper
    Broomfield, CO
    I removed the front mud flaps. Thats it. No cutting. No rubbing anywhere. @Sean266 has ~36" tires on and he removed mud flaps and did a little plastic trimming. He has aftermarket wheels with greater offset though.
    The stock wheels will be 10mm closer to the upper control arm and spindle than my rock warrior wheels so it will be tighter. I cant say that it will for sure fit or not.
  10. Mar 19, 2014 at 10:25 PM
    csuviper
    Broomfield, CO
    10mm = .3937". I think I have about that much of a gap left but that will be very tight. I suggest doing some more searching around the Internet to see if others made them fit. Report back here on what you find out.
  11. Oct 22, 2016 at 11:29 AM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    What offset rims are you running?
  12. Oct 22, 2016 at 11:32 AM
    csuviper
    Broomfield, CO
    I have wheel spacers on RW wheels. ending offset is 18.24mm
  13. Oct 22, 2016 at 11:46 AM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    On a 305 70 18 tire would aftermarket rims with a +18 be good or should I go less? Trying to decide between 295 70 and 305 70
  14. Oct 22, 2016 at 11:48 AM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    The rims I am going with come in +18 & +0 offsets
  15. Oct 22, 2016 at 11:52 AM
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    My opinion would be to spending the extra few bucks and get a reputable and quality 4-6" lift from Fabtech. You can fit 35's with both of the those setups but not sure on the backspacing on the Texas Edition wheels if they work.
    If you are willing to do something smaller like a 3 inch, you have a few options. Full replacement coilover, upper arm, and an add-a-pack/block in the rear will give you 3" all the way around with a level look.
  16. Oct 22, 2016 at 7:15 PM
    csuviper
    Broomfield, CO
    I would do 18. Will stick out pas the fender a little. 0 might stick out too much
    Law323 likes this.
  17. Oct 22, 2016 at 7:25 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I think Fabtech requires no more than 5" back space. I think that means stock wheels would require nearly a 2" spacer....just as an example. I may be wrong but someone here will know for sure. Stock wheels being +60 for this example.
  18. Dec 19, 2016 at 9:43 AM
    jeremy84
    jeremy84 New Member
    Jeremy
    2007 white tundra trd
    I see everyone isn't mentioning the rim size which effects the measurements, especially when it come to determining how far the wheel sticks pass the fender.
    Does anyone know of anyone that is running 35's on a 8" oem(+60 offset) wheel with 3" spacers make a total of -16.5 offset or another set up that = 9" wide rim with 0 off set?
    F.Y.I this set up brings it pass the fender 1.5" pass the fender. I honestly just wanted an 1" wich you could get from a 2.5 inch wheel spacer that I seem to not be able to find. The 2" spacer is an option but it only brings it half an inch which I consider a tease when wanting to show some threads hanging out for that offroad look.
