3rdTundra's 2017 Double Cab Build
Discussion in '2.5 Gen Builds (2014-2021)' started by 3rdTundra, Jul 25, 2021.
  1. Jul 25, 2021 at 8:10 AM
    3rdTundra
    3rdTundra [OP] Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
    Beginning to gather enough modifications that I thought I should start to document.
    Year: 2017
    Model: Tundra
    Trim: SR5 TSS
    Exterior: Black
    Interior: Black
    Purchased: 2020
    Exterior:
    Stock 20" TSS wheels
    BFG K02 285/55R20
    Spray-in bedliner and OEM bed lighting
    BAK Industries Revolver x2
    Valhalla full skid plate/catalytic converter protection (with install write-up)
    V-Ring Bed-Rail Tie Downs
    Interior:
    Driver's side A-pillar handle
    AJT de-chroming accessories
    Tactical Molle Drawstring Magazine Dump Pouch
    Desert Does It driver's side front seat jackers
    Electronics:
    FRAC (Front & Rear Anytime Camera) with Natika front camera
    Performance:
    Stock
    Suspension:
    Stock
    avssuc, TundraTex and Wallygator like this.
  2. Jul 25, 2021 at 8:20 AM
    3rdTundra
    Central Texas
    AJT blackout kit for the console.
    Also Plastidipped the chrome piece on the bottom of the shift knob and shrink wrapped the chrome shift lever.
    Also used the AJT kit for the climate control knobs and vent rings.
  3. Jul 25, 2021 at 8:25 AM
    3rdTundra
    Central Texas
    Installed the Front/Rear Anytime Camera (FRAC) harness. Used the same setup as @Tchase . Also added the AJT Design climate control blackout rings while I had the dash apart. Sorry for the poor quality images. Phone camera/display artifacts. Image on screen is clear.
    Here is mounting location.
    NATIKA License Plate Backup/Front View Camera,IP69K Waterproof HD Great Night Vision Wide View Angle Reverse Rear View Backup Camera for Pickup Trucks Cars SUV Van RV etc
    https://www.amazon.com/dp/B07JCSYPPS?ie=UTF8
    First image is with camera 15 degrees down from horizontal.
    Second image is with camera at horizontal
    pvn.beluga, TundraTex, Tchase and 2 others like this.
  4. Jul 25, 2021 at 8:40 AM
    Wallygator
  5. Jul 25, 2021 at 9:30 AM
    :thumbsup:
  6. Jul 26, 2021 at 5:22 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Looking good!
  7. Jul 26, 2021 at 1:37 PM
    3rdTundra
    Central Texas
    Note full write-up in attachment at end of post.
    Added the full-plate set from Valhalla including the 3-piece engine skid plate, front catalytic converter protection plate (or transmission skid plate) and the rear catalytic converter protection plate (transfer skid plate). All are 1/8" powder coated steel plates installed using the optional pentagon security bolt set. Full write-up is attached. Thanks to @Classy63 for the plates and install support as well as @CmdrD8TA for his write-up of the front and rear cat plates which helped with my install and write-up.
    Don't worry. I installed the missing bumper valance and oil filter access plate bolts after the picture was taken.
    Edited 7/28/2021: Added information about the bumper valance bolts and washers in write-up. New write-up attached.
    Disclaimer due to this litigious society... Please note that this is just a write-up of my installation experience. No warranties are expressed or implied and if you use this information, you use at your own risk.
    TBS, BamaMan44, avssuc and 2 others like this.
  8. Jul 26, 2021 at 2:16 PM
    Classy63
    Classy63 Valhalla’s Shield guy
    Tyler
    Cypress Texas
    15 platinum Barcelona red
    Toytec Aluma 2.0 front and rear, Toytec shackles, Toytec add a leaf pack, Tuff Country UCA’s, Firestone bags with daystar cups. JBA long tubes, w/3” cats, Dirty Deeds TRD replacement, DAP tune, AFE filter
    I love you!!! This is great!!! I forgot to give you some little washers for the plastic tabs for the front bumper, but you did great!!!
  9. Jul 26, 2021 at 2:19 PM
    3rdTundra
    Central Texas
    With the 1/2" bolts I thought they might be too short if I added a washer. I am thinking that the same 3/4" bolts as for the oil filter cover plate might be good with washers added.
  10. Jul 26, 2021 at 2:47 PM
    3rdTundra
    Central Texas
    @Classy63 Do I have the bumper valance and oil filter cover bolt sizes correct? I was thinking that the bumper valance bolts should be metric, but they seemed to be 5/16"-18
  11. Jul 26, 2021 at 5:14 PM
    Classy63
    Tyler
    Cypress Texas
    All my bolts are standard
  12. Jul 26, 2021 at 5:25 PM
    3rdTundra
    Central Texas
    Right... Silly me, I was thinking the nuts were OEM. Forgot that they are welded to the front engine plate. I will pick up some washers for the plastic tabs on the bumper valance.
    Classy63[QUOTED] likes this.
  13. Aug 9, 2021 at 2:17 PM
    kittyhawk
    kittyhawk New Member
    Dave
    Houston/Buffalo Texas!!!!
    2015 Tundra Crewmax SR5 4x4
    6112/5160. Ranchhand rear bumper and Valhallas Shields.
    That's a Great instaltuon write up. BRAVO ZULU my friend....
  14. Aug 9, 2021 at 2:21 PM
    3rdTundra
    Central Texas
    Thank you!
  15. Aug 13, 2021 at 9:58 PM
    avssuc
    avssuc Efilnikufesin
    Gulf Coast
    2021 Tundra TRD Pro LR
    Just bump quoting this again for the wealth of information it contains. You do a yeoman's work, friend.
  16. Sep 4, 2021 at 7:43 PM
    3rdTundra
    Central Texas
    Added V-Ring Tie Downs at the bed rail bolt locations. Added 4 v-rings on each side and 2 at the front of the bed for 10 tie-down locations. Decided to go this route for low cost and does not conflict with the BAK Revolver x2 cover.
    Used tie down anchors with 16mm M6-1.00 stainless bolts and 1/4"x1" stainless fender washers. Due to rust or debris in the mounting holes, had to use a 6mm-1.00 tap to clean out the threads prior to mounting.
    Remounted the bed-side V-rings down to reduce the risk of damage to the cover rails. Left the bed-front V-rings up since the cover roll is there anyway. Thanks for the assist @okcowboy and @biebs96
    https://www.amazon.com/dp/B07WQSYWN2?ref=ppx_yo2_dt_b_product_details
  17. Sep 5, 2021 at 1:06 PM
    Retired...finally
    Nice job. I think I'll do the same.
  18. Mar 20, 2022 at 12:49 PM
    3rdTundra
    Central Texas
    Wallygator and thetastelingers like this.
  19. Mar 20, 2022 at 12:55 PM
    3rdTundra
    Central Texas
    Wallygator and Jpd0144 like this.
  20. Mar 28, 2022 at 7:19 PM
    TundraRV
    TundraRV New Member
    2021 SR5 SX Double Cab
    @3rdTundra how did you actually mount that chalk bag to the side of the centre console? I don't have a Moelle Panel there. Thanks!
  21. Mar 29, 2022 at 7:36 AM
    3rdTundra
    Central Texas
