3rd GEN - USB Media Port - Supported Audio Formats (MP3, FLAC, WAV)
Discussion in '3rd Gen Tundras (2022+)' started by Adam_1794, Sep 28, 2022.
  1. Sep 28, 2022 at 7:56 AM
    Adam_1794
    Adam_1794 [OP] New Member
    MA
    22 1794 Metallic Black -Tow package/AVS/Air
    I've loaded up a 512GB micro SD and am quite surprised to see that the stock media system supports FLAC - even more surprised by the supported sample/bit rates. I have several albums in 192kHz/24 Bit playing nicely with zero lag or issues loading.
    Upon initially plugging in the USB drive, I did notice about a min or so delay in being able to access the music folders. I assume the system was indexing in some fashion. Sorting by albums is also nonexistent (likely due to indexing). As long as I can access the albums via folders I'm fine with it. The indexing is also odd, as I've noticed not everything is in alphabetical order... Not sure why it does this. One other complaint while searching the folders is the number of readable characters on the display is.. limited, to say the least. Keep your folder names short and it'll be easier to find things.
    Although the JBL system isn't perfect, it's far better than I expected. The imaging in the cabin is done well. I find myself preferring surround sound turned off for most of my listening as I feel it lessens the sound field and depth of the audio. The Treble/Mid/Bass adjustment is very limited and I wish some sort of EQ and subwoofer level control was available. Overall, I find the system to be a bit bass-heavy.
    Audio formats I've run:
    FLAC, WAV, MP3
    Audio formats I will be trying:
    OGG, ALAC, AIFF
    sablue and Taikowaza like this.
  2. Oct 3, 2022 at 8:26 AM
    nodak67
    nodak67 New Member
    JR
    if you look in the multimedia manual it lists all the formats it supports. start at page 224 (8-1 appendix)
    USB communication format USB2.0 HS (480MBPS)
    File format FAT 16/32
    Communication class Mass storage class
    Maximum number of folders 3000 (including root)
    Maximum number of folder levels 8
    Maximum number of files 9999 (maximum of 255 files per
    folder)
    Memory capacity Up to 32 GB
    Maximum size of one file 2GB
    Adam_1794[QUOTED][OP] likes this.
  3. Oct 3, 2022 at 8:33 AM
    j.b.
    j.b. New Member
    Jake
    2022 Platinum MGM
  4. Oct 3, 2022 at 2:05 PM
    Adam_1794
    MA
    Nice! Didn't see that. Saves me the time testing. I'm all FLAC for the most part
    Reads perfectly fine off the 512GB SD card formatted to FAT32.
  5. Oct 3, 2022 at 2:30 PM
    Breathing Borla
    Northern Illinois
    that was my point above, does super high fidelity audio really matter that much through a stock JBL system thats tuned like shit and have cheap ass speakers and hardly any amp power?
    I think it would not be much different, but alas, all my JBL stuff is sitting in a pile in the basement.
    I have to put it back in this truck if/when they find a match for me
    Spickett78 likes this.
  6. Oct 3, 2022 at 4:27 PM
    Adam_1794
    MA
    As a sound engineer, I hear a difference. It's not a matter of the speakers, but more surrounding how much data you can feed a DAC. The source signal from any of the music streaming apps is highly compressed and must go through additional conversion before it gets to a DAC. Throw in Bluetooth, and there's another level of signal conversion prior to any amplification circuit. I won't even get into S/N ratio with all of these circuits and then the circuits to "filter" that noise out.
    With native lossless FLAC files sitting on a jump drive plugged directly into the head unit, you're feeding the DAC with a higher quality source. Sample rate has more to do with this DAC conversion than how many watts or whether your speakers are made from woven kevlar or silk from a donkey's ass... There's a saying in the AE world - "Garbage in = Garbage out." It doesn't matter if you have Focal's and a gold-plated 2-channel 1000w amp under your seat - all your going to do is amplifying hot garbage (if that's what your feeding it).
    Would I like to have a 32-band EQ on the T-panel with a dedicated Subwoofer EQ cutoff and level control - YES
    Is it perfect - NO.. At least it's better than limiting a DAC to 44.1/16 which they could have very well done, or not even giving us a USB option (although I would've preferred a dedicated SD slot, or two..)
    Speakers are rarely the weak point. The fact that the USB 2.0 port accepts FLAC/WAV/ALAC/OGG is great. What's even more shocking is that the DAC is supporting and converting 192/24.
    I don't know what the amp specs are, speaker impedance, how many watts per channel, etc... It's plenty loud for me. Give it a good source signal and enjoy!
    Spickett78 and ryanwgregg like this.
  7. Oct 4, 2022 at 6:03 AM
    nodak67
    nodak67 New Member
    JR
    sadly for me i gave up the the audiophile phase about 30yrs ago. i can tolerate music/spotify some times, otherwise i am just as happy with no music at all. i use to have a 4k music file collection on my phone but i quit that about 7 years ago. use to like to watch tv also but meh, cant stand it anymore. which leads into the dvd situation. have just started a dvd collection on my media server, up to about 140 movies and i only use dvd quality. never saw a need for blu-ray since i only watch them on my phone when i have to travel or camped in the motel room during business trips. sometimes i throw one up on my secondary 34in widescreen display when playing on my main 43in 4k for background effect or in between lulls in gameplay.
    for my use case the quality wasnt the driving factor for my situation since its mostly background noise most of the time.
  8. Oct 11, 2022 at 7:20 PM
    bigblue14
    bigblue14 New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    Adam_1794[OP] likes this.
  9. Oct 11, 2022 at 7:29 PM
    Adam_1794
    MA
    UPDATE: Yet ANOTHER Nanny feature of the '22... Cycling through music folders via USB is limited WHILE IN MOTION and a little helpful message appears... What really pisses me off is this doesn't happen while searching via Spotify, Tidal, Radio, and XM Radio :frusty:
    Wonder if there's a disable option via Techstream?
    Spickett78 and X42069 like this.
  10. Oct 26, 2022 at 7:36 AM
    Adam_1794
    MA
    UPDATE: So started searching through my USB stick via "Artist" option vs. "Folder" and whaddya know - doesn't lock me out from scrolling endlessly while the truck is in motion! You can also drag up and down on the A-Z bar for quicker reference, not bad.
  11. Mar 16, 2023 at 8:20 AM
    gj953
    gj953 New Member
    East Coast
    2023 1794 Hybrid TRD OR Blueprint
    Silly question - does the system recognize .m3u playlists?
  12. Mar 16, 2023 at 8:43 AM
    nodak67
    nodak67 New Member
    JR
    i think is only recognizes audio formats per the mm manual.
    gj953[QUOTED] likes this.
  13. Mar 16, 2023 at 9:26 AM
    Spickett78
    Spickett78 New Member
    Seth
    2023 Tundra Crewmax 6.7' Limited TRD OR Premium Magnetic Gray
    3" TRD lift Talon's Garage Steel powder coated transmission skid plate / Cat cover RCI Steel powder coated skid plate Go Rhino D6 steps Nytop front recovery points
    Although this thread is mainly audio formats, I have a related question. Even if parked there appears to be no way to play a movie file of any type for my kids or myself for that matter. Why not since I have a massive screen in this thing.
    Compared to my friends taco turd pro the upgraded audio is a lot better. You can't even tell he has a sub and it's really similar to the Tundra setup. The lack of any good EQ options also confuses me. There is a LOT I love about my 3r gen Tundra and my previous 3rd gen Taco but Toyota just isn't nearly as advanced when it comes to user friendly software. I looked at F-150s in the year I waited for my Tundra and they operated better as does my wife's Hyundai Palisade. It's actually FAR superior in its user interface/function.
