3rd gen : Stock / Lifted ride height measurement request [hub to fender]
Discussion in 'Suspension' started by BlueBottle, Dec 3, 2017.
  1. Dec 3, 2017 at 7:13 PM
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    does anyone have their stock height ride height measurement from their 3rd gen crewmax they can share? I need center of hub to bottom of fender. If you have a lift kit, feel free to share It here too.. but please center of hub to fender only. this removes tires in the equation.
    Here is the compilation of members that have contributed. Keep them coming and I will continue to update this spreadsheet.
    Please use the following when contributing:
    Vehicle Type - scsb, sclb, dcsb, dclb, cm
    Lift/Suspension
    FL measurements
    FR measurements
    RL measurements
    RR measurements
    Chart
    @BlueBottle
    @shockinyall
    Stock
    3/1
    @Netmonkey
    How to properly measure Center of Hub to Fender
    this is an accurate way to measure ride height without tires/air affecting the equation
    1. Get values for A & B.
    2. B=wheel diameter ÷ 2 (my 18" wheel actually has a 19.5" diameter)
    3. A=bottom of wheel lip to Fender
    Example :
    B : 19.5" ÷ 2 = 9.75"
    A : 34.5"
    34.5"(A) - 9.75"(B) = 24.75"(center hub to fender)
    For those visual people
  2. Dec 3, 2017 at 8:13 PM
    TheBeast The Beach
    24" rear, 23 1/2 front. stock rear with KING 2.5 and KING 2.5 front coilovers factory height (roughly 2" I think)
    CaptSpaulding and BlueBottle[OP] like this.
  3. Dec 4, 2017 at 5:07 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
  4. Dec 4, 2017 at 1:51 PM
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    Bone stock 2017 Crewmax, no load.
    Passenger
    Front- 21.75in
    Rear - 24.25in
    Driver
    Front - 21.50in
    Rear - 24in
    shizzonline, Pudge and BlueBottle[OP] like this.
  5. Dec 4, 2017 at 2:13 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    Do you feel like the boss 2.5s came set lower than your old lift? Mine were bit lower too when they came.
  6. Dec 4, 2017 at 2:45 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    The Radflo's 2.5 I believe are preset at 2" of lift. I didnt even try it on the preset height. We cranked it up already before first putting the truck on the floor. And I still feel Im not at 3" ride height. I don't know if I want to crank them anymore. It feels like the ride is getting firmer and firmer the more I crank them.
  7. Dec 4, 2017 at 3:02 PM
    TheBeast The Beach
    to be expected. how about your CV angles ? looking ok ?
  8. Dec 4, 2017 at 3:17 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    It’s there lol. I have the diff drop but I honestly think they don’t do much.
    TheBeast[QUOTED] likes this.
  9. Dec 17, 2017 at 10:18 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Updated OP with spreadsheet. Will keep this going as people contribute.
    TheBeast likes this.
  10. Dec 17, 2017 at 11:11 AM
    TheBeast The Beach
    good stuff. thanks for keeping up
    BlueBottle[OP] likes this.
  11. Dec 17, 2017 at 11:33 AM
    RMFTundra
    RMFTundra New Member
    2014 Tundra TSS CM
    6”PC Stage2, PC UCA,35x12.50R20AT, Bakflip,Tint,Hypertech, SpidrTrx, Linex Bed & wTech Floor Liners
    Bluebottle, I may have mis-quoted originally, or maybe you transposed the deminsions when building the table. The correct before lift Front Right should be 22.25 not 23.00. And the before lift, Rear Left should be 23.00 not 22.25.
  12. Dec 17, 2017 at 1:11 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Thanks for noticing - fixeD!
  13. Dec 17, 2017 at 3:52 PM
    RMFTundra
    2014 Tundra TSS CM
    May need to add a truck description attribute to the table such as: truck age or perhaps mileage at time of lift mod. For example, my “before” lift measures were on a 35k mi frame. Since the day I drove it off the lot, it’s utility and payload capacity was tested, eg, hauling firewood, sand, shingles, lumber, etc. Point being, my before lift baseline I measurements were probably different than when it was new. Just saying.
  14. Dec 19, 2017 at 7:30 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    @RMFTundra thats a great idea but is more work :rofl:
    I have updated the OP with instructions and a diagram on how to properly measure hub to fender.
  15. Dec 20, 2017 at 11:36 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    @TheBeast @RMFTundra @MistrRoboto @Netmonkey
    For anyone that has contributed and want to share a profile pic of their truck, I will add it to the OP. It could help people trying to figure out what that particular lift looks like.
  16. Dec 20, 2017 at 11:46 AM
    TheBeast The Beach
    I will try to take measurements this week end as described here.
  17. Dec 20, 2017 at 12:04 PM
    shockinyall
    shockinyall Hillbilly
    West Virginia
    2017 TRDOR CM
    In Queue...
    2017 Crewmax
    Stock then LRO and now have the Toytec/Eibach Pro coilovers that i haven't measured, but is basically the same as the LRO. All measurements were full tank of gas, and no one in truck.
    Stock Picture:
    After 3-1 LRO Lift (and like I said above, basically the same with the eibachs)
  18. Dec 20, 2017 at 12:07 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Wow nice documentation! You have a 1” block in the rear?
  19. Dec 20, 2017 at 12:10 PM
    shockinyall
    West Virginia
    2017 TRDOR CM
    In Queue...
    Thanks. Yeah its 1". I kept the block and diff drop from the LRO kit and added the new coilovers.
  20. Dec 20, 2017 at 12:12 PM
    Netmonkey
    Georgetown, TX
  21. Dec 20, 2017 at 12:44 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Thanks Everyone! Updated OP!
  22. Dec 30, 2017 at 9:56 AM
    RMFTundra
    2014 Tundra TSS CM
    Here are a few picks for others to view relative to measures provided:
  23. Apr 15, 2018 at 2:58 PM
    WhiteLightning13
    WhiteLightning13 New Member
    Josh
    2020 Toyota Tundra SR5 Crewmax 4x4 Cavalry Blue
    Rough Country Leveling-Lift kit. Bakflip MX4 Bed Cover
    Hi all! I decided to put a Rough Country leveling kit on my 2013 Tundra, but the front end looks higher just with the naked eye. I have the 2” spacer with 2 - 0.25” shims installed on top of the strut assembly. I took some measurements and the front end is 0.25” higher, hub to fender. However, fender to ground/tire were equal all around (weird).
    My question is, if I remove one 0.25” shim, will this be a true 0.25” drop in the front, making it level?
  24. Apr 15, 2018 at 4:47 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Removing a 1/4” shim will drop you 1/2” of height.
  25. Apr 16, 2018 at 5:11 AM
    RMFTundra
    2014 Tundra TSS CM
    I had the same stance issue - or visually it seemed after 6” lift. Seems rear leaf springs settled over time prior to lift due to heavy loads, trailering, etc. After much research regarding options to get the rake I wanted, eg shackles ext, different leaf packs, etc., I opted to install airbags w/cradles. Looks great and solves my handling issues when trailering toys.
  26. May 20, 2018 at 9:04 AM
    kirk1963
    kirk1963 New Member
    Just had my '18 done and Bottle pointed me to this great thread - Toytec Radflo, Toytec Shackles top setting, diff drop, carrier bearing kit, SCS 18 25 offset rims/Toyo AT2 295/70/18s and JBA UCAs. Had to do cab chop mount but unclear if its because of the alignment guy not adjusting for the high caster JBAs (or rather me asking him to, he aligned with the stock tires on) and unadjusted Radflos with < 3" of height.
    My front hub measurements [A-B] (with no adjustment as received) after install are 24.75 passenger and 24.25 Driver from stock 22/22.5 or ~ 2.25" lift. Alignment: Caster 3/3.4, camber, .3/0, toe +.15/.15
    I'm going to readjust and align after a few hundred miles to get to 3"
  27. May 20, 2018 at 9:17 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    @BlueBottle I'm late to this thread, but I see no one has given you 6112/5160 #'s yet. I'll be happy to measure for you but itll probably be tomorrow afternoon before I can get to it.
  28. May 20, 2018 at 10:19 AM
    RMFTundra
    2014 Tundra TSS CM
    Air bags installed. Surprised how easy this was to. Added 10 psi to the bags to increase rear bed height 3/4”. Took it for off road spin and hauled boat for for testing - couldn’t be happier with the decision. Killed2 birds (towing & rake) with one stone. Now I have the rake I was looking for loaded and unloaded. Ride is also much better when towing.
    BlueBottle[OP] and equin like this.
  29. May 20, 2018 at 10:40 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    For sure! More is better than less!
    Sweet. I want airbags too but I read they limit articulation. Is that true? Is the ride on the street better with them?
  30. May 20, 2018 at 10:55 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    They do limit articulation. And can tear when you're tires go full droop. You'll want to get a set of airbag cradles, which allow only one point of fastening on the bags so you can go full droop. Daystar makes cradles.
    I had them on my tacoma, were nice for when I added weight or towed. Ride was slightly rougher because they always need some air in them, 5psi I think. I used a bike pump to add air, very easy and quick, only took a few pumps to adjust them to the load I had in the truck
