3rd Gen non-JBL amp upgrade
Discussion in 'Audio & Video' started by k9shag, Jan 9, 2019.
  1. Jan 9, 2019 at 3:05 PM
    k9shag
    k9shag [OP] New Member
    Tony
    Midland, NC
    2017 Tundra DC SR5 MGM
    I have searched through many threads and maybe I missed it or just don't have enough technological aptitude. I am looking to upgrade my non bbl amp with a plug and play amp to help hear the speakers. I am not one who needs bass just want to give the stock system a little jolt.
  2. Jan 9, 2019 at 3:10 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Adding an amp with stock everything else isn't really plug and play. May as well upgrade other stuff while you're in there.
  3. Jan 9, 2019 at 3:12 PM
    k9shag
    Tony
    Midland, NC
    suggestions? I do not want to change the HU
  4. Jan 9, 2019 at 3:13 PM
    ninjajay
    Spoolston, TX
    Boots likes this.
  5. Jan 11, 2019 at 8:08 AM
    k9shag
    Tony
    Midland, NC
    I emailed James and his suggestion was to replace the entire system. That is not what I was looking to do. I will check OEM+ thanks
    IndianaGeologist likes this.
  6. Jan 11, 2019 at 8:22 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    It might not be what you want to hear, but its the truth. There's nothing wrong with doing the upgrade in stages, but you will keep finding weak links.
    The paper cones cant handle too much power, so if you do just upgrade the amp, dont crank it, but the signal coming from the HU is so dirty, you might want to try to clean it up before you amplify it. You might throw in a Fix86 or LC7i.
  7. Jan 11, 2019 at 8:24 AM
    Danimal86
    Daniel
    Sacramento, CA
    I thought people were getting a crazy hiss with that?
  8. Jan 11, 2019 at 12:24 PM
    Boots
    Boots New Member
    Houston Tx
    2018 black tundra
    Procomp 6in lift w 35's 30in grill light bar Bac bed cover Taco tunes sq1 sound system Tinted windows Custom Masonic grill.
    Look at taco tunes website. They have a budget system that I know you'll like and yes its plug and play w no cutting of any wires. I have their best system sq1. You wont go wrong using them
  9. Jan 11, 2019 at 1:08 PM
    Azblue
    The Dirty T ( ^_^)_且
    Swapping the stock amp on a non JBL is an easy and affordable way to get a pretty decent system. Just need to run a new power and ground for the amp and either repin a couple of aftermarket harnesses or I believe they are now available ready to go fairly cheap from a couple of companies.
    Even better, use a 5 channel amp and add a sub. I run a Alpine MRV-V500 with a Alpine 10" in a box I made. The stock door speakers will surprise you with a little power to them, however I did eventually upgrade mine.
    Cobshop likes this.
  10. Jan 11, 2019 at 4:02 PM
    k9shag
    Tony
    Midland, NC
    Thanks I have looked at that and am considering this route.
    not sure where a sub would go in a double cab
  11. Jan 11, 2019 at 4:07 PM
    Klebrchelp
    Klebrchelp New Member
    2019 Tundra
    OEM+ audio, Icon Stage 5, Spod Bantam, ESP under seat full storage, Roll n Lock aluminum tonneau, console safe, Sound dampening, TRD exhaust, swaybar, Katskinz seats, Rago Fabrication mounts, Daja designs lights, more to come.
  12. Jan 11, 2019 at 4:38 PM
    Azblue
    I believe you have more options than I did in my CrewMax. You should be able to buy/make a box for either behind or under the back seat.
  13. Jan 11, 2019 at 4:40 PM
    Klebrchelp
    2019 Tundra
    https://oemaudioplus.com/toyota/tcm/
  14. Jan 11, 2019 at 4:45 PM
    Boots
    Boots New Member
    Houston Tx
    2018 black tundra
    The amps will go under the passenger front seat. The subs behind the rear seat.
  15. Jan 11, 2019 at 4:52 PM
    Boots
    Boots New Member
    Houston Tx
    2018 black tundra
    Here20181102_153254.jpg 20181102_153218.jpg are a couple pics of mine that taco tunes did. Hope this helps you.
  16. Jan 11, 2019 at 5:12 PM
    offshore2005
    offshore2005 New Member
    TEXAS
    2022 Tundra Limited 4x4 RC leveling kit and 295/65/20 Cooper STT PROs
    I added this.. just needed a line out converter and an add a amp harness from taco tunes. BD1B0978-A9C3-451D-9A32-3585D1033474.jpgA4EC89B3-3018-4605-8F7B-3F93956E9D57.jpgAlso changed out my dash speakers from 12 volt tech...... Sounds ten times better.
  17. Jan 21, 2019 at 8:51 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Here are pics of the sub box, amplifier and LC2i audio controller.
