3rd Gen molle - Rough Country
Discussion in '3rd Gen Tundras (2022+)' started by J78R, Oct 12, 2024.
  1. Oct 12, 2024 at 5:11 PM
    J78R
    J78R [OP] New Member
    Jonathan
    2024 Tundra Platinum TRDO
    Predator step bars Weathertech cover AFE front tow hooks NYTOP rear tow hooks
    Just installed the Rough Country bedside molle panels, wanted to provide my experience in case anyone else is interested.
    Price point is great, each panel is one solid piece, and the design preserves the bed cutouts near the tailgate if you use that as a divide. Passenger side tie down attachment (near the cab) didn’t fit at first, had to drill two holes for the bolts to line up.
    Once you’ve attached the panel to the rails and tie downs, it’s pretty rock solid. There is an additional tab at the bottom to drill into the bed and secure with a nutsert. I didn’t do this yet and instead just secured it with a screw and rubber spacer; there was so much tension already I felt the drilling wasn’t needed.
    Aside from a minor mod to fit, it’s been great. Time will tell.
  2. Oct 12, 2024 at 5:58 PM
    Bnewman077
    Bnewman077 Happy 2023 Owner
    2023 Tundra TRD OR Lunar Rock
    18” Method Wheels, 35x12.5 Toyo AT3, TRD Pro suspension with Westcott preload lift and Icon rear springs
    do you have pictures of it installed? would it work with the tie down rail relocated lower for tonneau cover
    WingedHussar likes this.
  3. Oct 12, 2024 at 8:35 PM
    kamaaina1
    kamaaina1 New Member
    2024 Tundra TRD PRO
    Camburg 4-Link, Bed Molle panels, Pelican cargo bin, TRD drop-in Filters
  4. Oct 13, 2024 at 7:53 AM
    J78R
    Jonathan
    It mounts directly behind the factory rails and didn’t change their location. I have the Weathertech trifold which is essentially just a few compression clamps in the rail track; no issue. I’d like to get a Diamondback eventually which I think would still work.
    Based on your cover design with the rails mounted lower, you may have to take everything apart, mount the panel first, then reassemble. Sorry should've included pics:
    RatPanda and Tunrod like this.
  5. Oct 13, 2024 at 7:58 AM
    Hella Krusty
    Hella Krusty New Member
    I don’t understand what these are for?
    Woodrow bangs likes this.
  6. Oct 13, 2024 at 8:09 AM
    taijai
    taijai New Member
    2024 Toyota Tundra Limited Mesquite 4x4
    @Hella Krusty extra mounting points mostly. You could strap things like a fire extinguisher or something
    Hella Krusty likes this.
  7. Oct 13, 2024 at 8:15 AM
    Savagesawyer
    Savagesawyer New Member
    Beaverton, OR
    These rock climbers/boulderers trying to get it in wherever they can.
  8. Oct 13, 2024 at 9:09 AM
    kamaaina1
    2024 Tundra TRD PRO
    Nice install!
    Here's mine. I "made" the Amazon version work, despite the drop rail. I just used the first molle row as mounting points, instead of the higher mounting slots on panels. I'll probably rearrange accessories as needed/wanted.
    Savagesawyer likes this.
  9. Oct 13, 2024 at 9:42 AM
    SoCal_Erik
    SoCal_Erik New Member
    2023 SR5 Sport 4x4, 2016 4Runner
    Instagram.
  10. Oct 13, 2024 at 10:09 AM
    Savagesawyer
    Beaverton, OR
    But bro, I have the finest fire extinguisher, axe, and shovel combo in my county, how else am I going to show it off??
  11. Oct 13, 2024 at 12:14 PM
    J78R
    Jonathan
    Instead of drilling, I used one of the tie down bolts supported by RC, threaded through and used two nylon grommets on the stem, each side. Each grommet was 3/8" ID, 1" OD, 3/8" length.IMG_8173.jpg
    Savagesawyer and RatPanda like this.
  12. Oct 14, 2024 at 4:05 PM
    Hella Krusty
    Looks like a spot to collect debris. Go get a load of firewood with those stupid things in there
  13. Oct 14, 2024 at 5:42 PM
    Woodrow bangs
    Woodrow bangs New Member
    Baltimore
    2023 MBM Platinum
    The more I look at these the more I can’t understand what would make sense actually mounted on them. They look ridiculous and in the way of everyday bed use. Looks like the inside version of the super handy bed racks.
