3rd Gen Infotainment Hacking
Discussion in '3rd Gen Tundras (2022+)' started by TheMuffinMan, Jan 19, 2024.
  1. Jan 19, 2024 at 8:18 PM
    TheMuffinMan
    TheMuffinMan [OP] New Member
    Idaho
    2021 DCLB SR5
    Hey all, was wondering if anyone has found any hacks or jailbreaks for the 2023 infotainment screen now that my trail/included year of features has expired?
  2. Jan 20, 2024 at 6:38 AM
    Woocawachie
    Woocawachie New Member
    Dickens
    Philadelphia
    2023 Tundra Limited CM 6.5. WindChillPearl
    Doubt anyone here messes with software, it’s not like we got Saurik to build us Cydia for this thing.
  3. Jan 20, 2024 at 6:45 AM
    DRP
    DRP Old Member
    Dave
    Woocawachie likes this.
  4. Jan 20, 2024 at 7:16 AM
    Woocawachie
    Dickens
    Philadelphia
    If I was going to try this, it would be for ability to install obd2 app so I can monitor my transmission temp while towing. My dinky 8 inch screen isn’t made for YouTube watching. That’s why I got the iPad Pro LTE for the kids in the back to watch. But having a separate phone to monitor trans temp is annoying.
  5. Jan 20, 2024 at 7:21 AM
    raylo
    raylo not so new member
    Frederick, MD
    You can monitor trans and engine oil temps with a ScanGage 2 or 3.
  6. Jan 20, 2024 at 7:30 AM
    raylo
    Frederick, MD
    The thing that really bothers me is that these newer vehicles' integrated infotainments and non-standard physical configurations pretty much eliminate the chance to go aftermarket. Back in the day not that long ago a simple head unit swap was all that you needed to get the latest and greatest. Now, at least for those of us with the 14", not happening... and if it ever fails out of warranty, we are probably talking several thousands of $$ to repair.
  7. Jan 20, 2024 at 7:33 AM
    Woocawachie
    Dickens
    Philadelphia
    Good point. Might invest in one
  8. Jan 20, 2024 at 7:36 AM
    raylo
    Frederick, MD
    I like the old school SC2 for the small form factor and simple display. I have mine mounted on the steering column. One caveat with these is that unless they have changed their baseline setups you need to program them to display mfg specific parameters like these. It isn't that hard but can be a little finicky and annoying, stepping through some menus and entering the parameter codes.
  9. Jan 20, 2024 at 7:43 AM
    Woocawachie
    Dickens
    Philadelphia
    So on SC3 I see you can just auto scan and it will pull up all existing sensor values, the SC2 doesn’t have that? How do you find the Trans Temp code then?
  10. Jan 20, 2024 at 7:43 AM
    mrfreeman
    mrfreeman New Member
    Kenny
    Buffalo
    2024 Tundra SR5
    I miss the days of jailbreaking
  11. Jan 20, 2024 at 7:52 AM
    raylo
    Frederick, MD
    Pretty cool if SC3 does that automatically. For SC2 you go to their website and there are tables with make/model, etc and a list of supported parameters. Then you take those codes and go into the device edit function and enter the codes. It is like old school texting just stepping through each character to get to the letter or number that you need. And each data field is like 10 or more characters long IIRC. The other small catch is that there may be more than one code listed and you just have to do trial and error.
    But there are some threads here where we have already figured these codes out and I'll look to see if I can find it.
    Edit: here is the table to use for SC2, the 3.5l table: » TOYOTA – LEXUS – SCION (scangauge.com) Also, be advised that there is only one transmission temp for our Tundras.
    Woocawachie[QUOTED] likes this.
  12. Jan 20, 2024 at 8:23 AM
    Woocawachie
    Dickens
    Philadelphia
    Thanks. I think I might stick with SC3 even tho it’s bigger screen
    raylo[QUOTED] likes this.
  13. Jan 20, 2024 at 8:29 AM
    raylo
    Frederick, MD
    I really like it, too, but the form factor makes finding a good spot for it more difficult. And for me, once this this is set up, I don't ever mess with it so the extra functions don't really matter to me. Good luck.
  14. Jan 20, 2024 at 8:30 AM
    Woocawachie
    Dickens
    Philadelphia
    if you look at the fine print for the extended warranty there’s a lot of things that aren’t covered. I’m also planning on buying the warranty but mostly for the turbos than anything else.
  15. Jan 20, 2024 at 8:31 AM
    raylo
    Frederick, MD
    Seriously? That's terrible. I was thinking about getting that plan, too.
  16. Jan 20, 2024 at 8:36 AM
    T315
    T315 New Member
    2022 Tundra Crewmax TRD Offroad
    What is your 14" dash controlling that an 8" is not? Are you sure your infotainment is really controlling anything at all? I swapped from my 8" to a 14" screen and I can see my truck on the toyota app like nothing ever happened.
  17. Jan 20, 2024 at 8:38 AM
    raylo
    Frederick, MD
    Thinking more about the physical hole to somehow make an aftermarket work. It would be easier to make a kit to convert the 8" to double DIN.
  18. Jan 20, 2024 at 8:43 AM
    T315
    T315 New Member
    Oh, the 14 and 8 inch mounting slots are identical behind the screen. But double din are so early 2000's, I wouldn't even want it on any 2020+ cars with factory android auto/carplay.
  19. Jan 20, 2024 at 8:46 AM
    raylo
    Frederick, MD
    I agree... and there are bigger aftermarkets now. I plan to keep mine stock, but if it fails and there is a $3,000 repair bill? IDK.
  20. Jan 20, 2024 at 8:49 AM
    T315
    T315 New Member
    hopefully by then, we have more blown engine tundras to pull parts from. haha
  21. Jan 20, 2024 at 4:22 PM
    TheMuffinMan
    Idaho
    2021 DCLB SR5
    I don't care about Netflix but I'd love maps (without navigation), or diagnostics like Torque where I can customize what sensors are displayed which would be pretty neat. If I could get android running on the stock head unit I could control my drone which would be sweet.
  22. Jan 22, 2024 at 5:59 AM
    nodak67
    nodak67 New Member
    JR
    toyota financial vsa platinum
    https://www.toyotafinancial.com/con...eement/TFS_VSA_Platinum_eBrochure_Jan_204.pdf
    COMPUTERS AND ELECTRONICS
    Airbags; Airbag Sensors; Antenna Cord; Anti-Lock
    Braking/Traction Control Computer and Sensors;
    Automatic Shoulder Belt Computer; Body Control Module;
    Circuit Opening Relay; Compact Disc (CD) Player; Cruise
    Control Computer; Electronic Ignition Unit; Electronically
    Controlled Transmission/Transfer Case Computer
    and Sensors; Electronically Modulated Suspension
    Computer; Engine Control Computer; Front Seat Airbag
    Assembly; Graphic Equalizer; Knock Sensor; Navigation
    System; Power Mirror Electronic Control Unit; Power Seat
    Computer; Progressive Power Steering Computer; Radio
    Tuner; Steering Sensor; Stereo Component Amplifier;
    Sunroof Control Computer and Relay; Tape Player;
    Tilt/Telescoping Steering Computer; Traction Control
    Computer; Trip Computer; Variable Induction System;
    Vehicle Security Computers and Sensor; Wiper Module
    THESE ARE THE ITEMS NOT COVERED
    Accessory Drive Belts; Batteries; Body Panels; Brake
    Linings, Pads, and Shoes, Rotors and Drums; Bumpers;
    Carpet; Chrome; Clutch Friction Disc and Pressure
    Plate; Dash Cover and Pad; Door Fabric; Door Trim;
    Filters; Fluids; Fuel Cell Air Compressor; Fuel Cell Boost
    Converter; Fuel Cell Electronic Control Unit; Fuel Cell
    Hydrogen Tanks; Fuel Cell Power Control Unit; Fuel Cell
    Stack; Fuel Cell Vehicle Battery Pack; Glass (including
    Windshields); Headliner; Heating Hoses, Lines, and Tubes;
    Hoses; Hybrid Vehicle Battery Pack; Hybrid Vehicle Battery
    Plug Assembly; Hybrid Vehicle Relay Assembly; Hybrid
    Vehicle Supply Battery Assembly; Hydrogen Fueling
    Electronic Control Unit; Interior and Exterior Trim and
    Moldings (including but not limited to: Ashtrays, Covers,
    Cup Holders, and Vents); Lamps, Light Assemblies/
    Housings, and Light Bulbs; Nuts, Bolts, Clips, Retainers,
    and Fasteners; Paint; Rust and Corrosion Damage; Seat
    Covers; Sheet Metals; Shiny Metals; Spark Plugs; Structural
    Framework and Welds; Tires; Vacuum Hoses, Lines, and
    Tubes; Weather Stripping; Wheels and Rims; Windshield
    Wiper Blades (rubber component); All interior and
    exterior cloth, leather, and stitching including convertible
    tops and/or vinyl tops including but not limited to: any
    vibration, deterioration, discoloration, disfigurement,
    warping, fading, staining, stretching, ripping, punctures,
    tearing, and/or scratches
  23. Jan 22, 2024 at 11:38 AM
    Woocawachie
    Dickens
    Philadelphia
    I am very torn about buying a warranty right now. In two years my lease will be over and I have the option to buy out the truck for $40,000. The question is will it be worth $40,000?or will I be able to find another used tundra for the same price in a higher trim level (my is just SR 4x4) with similar mileage that would be a better deal. Choices choices…..
  24. Jan 22, 2024 at 12:36 PM
    Woocawachie
    Dickens
    Philadelphia
    You have a place that has better prices?
  25. Jan 22, 2024 at 12:41 PM
    nodak67
    nodak67 New Member
    JR
    to get a toyota new vehicle vsa, you have to purchase it before 3 yrs/36k miles from 1st in service date including lease's
    edit : the above statement is misleading as lease's have a unique lease vsa i think.
    if its a lease, you could go the used toyota vsa route, those are more expensive and the time/mileage start from the used buyout date. and from what i remember, you have to buy it at time of sale.
    not sure if a buyout after a lease can be seen as a used vehicle. either go thru the certified route warranty or the used car vsa route.
    used car vsa is 1yr/12k up to 5yr/60k from date of sale
    tcuv (toyota certified used vehicle) vsa doesnt mention timeframe.
    you can look all that up
    https://www.toyotafinancial.com/us/en/vehicle_protection_plan/vehicle_service_agreements.html
    just select different dropdowns for new, tcuv or used vsa agreements.
    edit: only the new vsa you can shop around for and usually get a lower price than 99% of the dealers will charge.
    tcuv and used can only be bought at time of sale, so there is no wiggle room on time/price.
  26. Jan 22, 2024 at 3:56 PM
    4genRunner
    4genRunner New Member
    Southwestern MO
    2022 SR5 CrewMax TRD OR 4x4 CSM
    RB20's, Extang Xceed Cover, Tint.
    It does. I had an SG2 in my previous 4Runner (mounted on the column) and agree that adding in codes is somewhat tedious. I went for the SG3 in the new Tundra and it scans and automatically displays all of the items you can monitor. Being able to monitor 9 parameters on a single screen while towing is pretty slick. I mounted it just behind and to the left of the 14" screen and it works really well for me.
  27. Jan 22, 2024 at 4:20 PM
    Woocawachie
    Dickens
    Philadelphia
    My dilemma is. Is it worth buying it now ( at 10k miles on it) if at the end of the lease I won’t be buying the truck out. I think for $40k I’ll be able to find something better.
  28. Jan 23, 2024 at 6:53 AM
    nodak67
    nodak67 New Member
    JR
    toyota has a lease vsa which is not the same as a new vehicle vsa. be mindful of that.
    if you lease, you can only get the used or certified vsa after you do the buyout.
  29. Jan 23, 2024 at 11:12 AM
    raylo
    Frederick, MD
    Can you post a photo? What mount did you use? Sounds like I might need to upgrade.
  30. Jan 23, 2024 at 8:50 PM
    4genRunner
    Southwestern MO
    I used this mount - https://www.amazon.com/dp/B0912GR7CK
    The bottom of the mount sits in the tray in the dash behind the stereo. The arm that came with the mount was not long enough, so I printed my own arm out of ABS and used the other parts of the mount. I also used a small strip of 3M VHB tape on the bottom of the SG3 and the mounting is solid. I dremeled out a small channel next to the 12v socket in the tray and ran the ODB cable up through the dash and out that channel.
    I’ll grab some pics in the morning and can send you the stl for the arm (or just throw it up on thingiverse) if you need it.
    raylo likes this.
