3rd gen coolant level when cold.
Discussion in '2.5 Gen Tundras (2014-2021)' started by BTBAKER, Feb 16, 2020.
  1. Feb 16, 2020 at 4:53 PM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    May I trouble a few of you to show me a picture of your reservoir when the engine is cold.
    I have two black marker lines on mine and my level seems low to me but I’m not completely sure where it should be.
    Thanks in advance!
  2. Feb 16, 2020 at 4:56 PM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    I see there is a min/max line. Should it be between the two when COLD?
  3. Feb 16, 2020 at 4:58 PM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    Also, the reason why I’m somewhat concerned is that on hot days I tend to smell coolant. I smelled it on my Taco and never had an issue. Normal?
  4. Feb 16, 2020 at 5:28 PM
    TheHutchTTU
    TheHutchTTU Wreck 'Em
    North Texas
    2020 Midnight Black Metallic TRD Pro
    Yes, always check/refill your coolant because the system will be under pressure when hot, and it should be somewhere between min and max. If you sneak coolant and you're having to add some, then it definitely sounds like you have a leak somewhere. I would start checking around the water pump and thermostat.
