3rd Gen Bumper Swap... Complete
Discussion in '2nd Gen Tundras (2007-2013)' started by 1BadTundra, Jul 26, 2018.
  1. Jul 26, 2018 at 12:36 PM
    1BadTundra
    1BadTundra [OP] New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    Ok, finally... Here it is. My 2010 RW, with a 2016 bumper. It took so damn long because I had to get a bunch of pieces to finish it off. The RW bumper is one piece, so I had to buy the upper bumper trim, and the retainer frame that it mounts to. I also pulled the factory fogs, and spray bed lined the bumper. I installed a 30" light bar behind the bumper grill, and cube pods with the adapter plates. I had to paint the upper bumper cap to match, then mount everything up. I did the 1/2" bumper spacer mod while I was in there. What do y'all think?
    WVI, Lou13_TSS, MrALF and 33 others like this.
  2. Jul 26, 2018 at 1:37 PM
    TheBeast The Beach
    looks great ! any plans on doing a full front conversion ?
    Prostar 190, airosey and lionix like this.
  3. Jul 26, 2018 at 1:45 PM
    I'm liking it!
  4. Jul 26, 2018 at 2:00 PM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    i like it. what was total cost?
  5. Jul 26, 2018 at 2:01 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Nicely done!
  6. Jul 26, 2018 at 7:00 PM
    Quebec
    Quebec New Member
    I'll take two, everything about it looks perfect!
    You don't happen to have a specific parts list on hand of what was needed?
    I assume Upper Cover - Toyota (52129-0C901) might be what you mentioned, not sure about the retainer frame though.
    More pics please:militarypress:
  7. Jul 26, 2018 at 8:49 PM
    airosey
    airosey 2009 CrewMax Limited 4x4
    East TN
    Slightly modified 2009 CrewMax Limited 4x4
    09 Tundra CrewMax Limited TRD Supercharger with URD pulley Tuned by OrangeVirus tuning (OV Tune) TRD Big Brake Kit with SS lines and titanium backing plates StopTech rear sport axle pack (rotors, pads, and SS lines) 7” Pro Comp lift 3” Performance Products Body Lift Coachbuilder 1” coilover shims Coachbuilder +3 shackles Coachbuilder Tie-rod ends 22x14 -70 Fuel Lethal’s - 2 piece 38x15.5 Mickey Thompson Baja Boss M/T’s King Shocks with remote reservoirs front and rear Nitro 5.29 gears front and rear Auburn LSD SPC adjustable UCA’s BAM 8” exhaust Pro Comp Traction Bars Enve Grille Smittybilt M1 front bumper Rough Country 12k lbs winch Demon Hook shackles front and rear Baja Designs Squadron Sport Amber and clear fog lights ADD HoneyBadger Rear Bumper with Rigid SR-Q reverse lights Sequoia Headlight conversion Switch-Pros SP-9100 mounted in overhead console SD Off-road MT under-hood tray AEM boost and afr gauges Hypertech Speedometer calibrator Bed and rear bumper are Bulletlined American Flag Headliner Mammoth Guards patriot edition Alpha and Omega Fabrication Patriot Hood shield 3rd gen door panels and steering wheel ProSpeed Catchcan Hornblasters Outlaw train horns Tufskinz real carbon fiber overlays Tufskinz carbon fiber B panels vLEDs footwell lighting front and rear vLED puddle lamps Lighting Trendz flow series wheel rings 16 RGB rock lights Toyota Bedmat Bestop Power folding steps Undercover bed cover Undercover SwingCase 4 gallon Rotopax fuel can Here’s a rundown of the audio setup. -Active front stage using a JL Audio TwK88 DSP, Focal 165KRX2 component speakers, powered by a JL Audio HD900/5 -Passive rear setup with Focal 165KRX2 component speakers -2 JL Audio Stealthboxes (13TW5’s) powered by a JL Audio HD1200/1 -Sony XAV-9500ES float mount display with a PAC Radio Pro 4 -Odyssey battery -JL 0 gauge power and ground cables -AudioQuest X-2 speaker cables and Golden Gate RCA interconnects -Entire cab has been lined with Dynamat Extreme and 1/4 CCF Amps and dsp are mounted under the passenger seat with a SoundsGoodStereo mounting plate.
    That’s the cleanest one I’ve seen yet!
    1BadTundra[OP] and Prostar 190 like this.
  8. Jul 30, 2018 at 10:56 AM
    PureTundra
    PureTundra PureTundra - A Pure Auto Parts, Company
    Ray
    Cedar Park, TX
    2010 Tundra, 2008 FJ Cruiser
    I think that I want one :spending:
  9. Jul 30, 2018 at 11:03 AM
    Looks great!
  10. Aug 1, 2018 at 5:37 AM
    1BadTundra
    Clinton
    Too Much to List
    Not really, though I do need new headlights and a PRO grille... Maybe down the road.
    $250 for the complete bumper assembly, I found a real cool fellow Tundra owner that gave me everything after he installed his new aftermarket bumper.
    $100 for the upper bumper reinforcement
    $80 for the upper bumper cover
    $50 in paint
    $50 for the fog light adapter plates
    We stock the spray bedliner material in bulk.
    A company promo'd me the light bar and cube lights, as our shop is a dealer for them.
    So probably just under $600 our cost.
    Yea, thats the upper cover 52129-oc901
    (52072-0C020) Bumper Retainer Sub-Assembly is the other part needed.
    trdprobped17 and Quebec[QUOTED] like this.
  11. Aug 1, 2018 at 5:38 AM
    1BadTundra
    Clinton
    Too Much to List
    Thanks guys, I love this look... It wasn't tough to do either, the hard part was making it all flow together.
  12. Aug 1, 2018 at 6:11 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    That looks good!
  13. Aug 1, 2018 at 7:01 AM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Good job that looks sweet.
  14. Aug 1, 2018 at 7:03 AM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    That looks fantastic nice job!
  15. Aug 1, 2018 at 7:18 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Looks great nice job. I really like the way the bedliner looks against the gloss black. Can we see a side shot of it please?
  16. Aug 1, 2018 at 7:38 AM
    EN2TUNDRA
    EN2TUNDRA NOT SO New Member!
    North TX
    2021 Tundra TRD PRO Lunar Rock
    Looks great!
  17. Aug 2, 2018 at 3:30 PM
    Brian3UR
    Brian3UR New Member
    2013 Silver Sky DC 4x4
    Drop in K/N filter with TRD airflow accelerator BullyDog GT Tuner 2.5" Suspension leveling kit TRD rear sway bar Line-X bedliner Charcoal Filter (in air box) delete Deleted screen in throttle body gasket Coolant to throttle body bypass LED lighting inside bed and under hood Center console from 2007 Tundra with LED light for cup holder Small amplifier and subwoofer to enhance factory radio BAMuffler TRD Dual Replacement system (on order) LED headlights, fog lights, brake, tail and interior lights Side mirror glass with turn signal indicators (from Platinum model)
    Looks bad-ass!
  18. Aug 2, 2018 at 6:00 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    That looks great!
  19. Aug 4, 2018 at 5:18 AM
    Jgarcia6820
    Jgarcia6820 New Member
    Jhonny
    2013 tundra rock warrior
    Flows nice!
  20. Aug 4, 2018 at 5:33 AM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    You did a great job. Thanks for sharing how bad ass a second gen can take it to the next level! Peace. D
  21. Aug 5, 2018 at 10:03 AM
    Tundracollector
    Tundracollector New Member
    16 Dc trd pro, 04 Dc, 08 rcsb
    Nice, all the ones I have seen done the corners never match right, this is probably the best one.
  22. Aug 19, 2018 at 9:55 AM
    1BadTundra
    Clinton
    Too Much to List
    Mine aren't perfect either... I used teh spacer mod to bring it out some, I still have to stretch the bumper some on both sides to get it out to where I want it.
  23. Aug 22, 2018 at 11:55 AM
    Walton
    Walton New Member
    Appleton, Wi
    2010 5.7L FFV LTD CrewMax
    Looks awesome!
  24. Aug 24, 2018 at 12:28 PM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    That’s pretty Dope!
  25. Aug 30, 2018 at 9:55 AM
    TXTundraSC
    TXTundraSC New Member
    College Station, Tx
    2011 Tundra Platinum 4x4 s/c
    Magnuson S/C, trd exhaust, trd rear sway bar, trd front sway bar, toytec 2.5” level, debadged, toyo r/t 305/55r20
    So if I have a 2011 Platinum with a 2 piece bumper, do you know what part numbers I would need to complete this? Is there any fabricating you had to do?
  26. Sep 11, 2018 at 11:48 AM
    Mattlikesbikes
    Mattlikesbikes New Member
    How did you pull in or push out to make it flow? Other versions show the upper trim being narrower than the new bumper by maybe 3/4" on each side. Did you pinch in the end caps, or flare out the upper trim?
    I guess if you are going the bedliner route (which I would) you can do a lot with the endcaps and just bondo and paint them right.
    Also, if it ends up fitting this well, any thoughts on why a Gen3 aftermarket bumper wouldn't mount right up, just below the straight line painted trim?
  27. Sep 30, 2018 at 4:50 PM
    1BadTundra
    Clinton
    Too Much to List
    Spacing the lower bumper out 1/2" makes it all flow much better. I didnt mod the bumper at all... yet. I want to pull the sides out each about 1/2" to give it a flared look. Yes, a 3rd gen bumper should fit right up
    Zoren Tundra and trdprobped17 like this.
  28. Oct 8, 2018 at 7:50 PM
    brettski7
    brettski7 New Member
    Brett
    So just the 3rd gen bumper is all that’s needed? Just pull my chrome one off and put this one on and good to go?
  29. Oct 9, 2018 at 7:31 AM
    1BadTundra
    Clinton
    Too Much to List
    As long as the bumper is complete, then yes, that's all you need. Meaning, all the inner bumper brackets that make the bumper a complete assembly.
  30. Oct 9, 2018 at 9:23 AM
    TheBeast The Beach
    got any side shots ?
    da_jeep_luva likes this.
