3rd gen brakes (pads and rotors)
Discussion in '2.5 Gen Tundras (2014-2021)' started by gears_call, Feb 18, 2020.
  1. Feb 18, 2020 at 5:59 PM
    gears_call
    gears_call [OP] New Member
    Orange County, CA
    2014 SR5
    King 2.5's l Method double standards l 35" BFG KO2 l SS Built front bumper/skid/valence l more to come....
    Hey all,
    just did the pads and rotors on my 14 CM. Did the manufacturers break in suggestions but still having a audible grading/squeak which I’ve localized to the rear. I’m presuming since it’s a drum brake set up the inner diameter of the new rotors is probably causing the drums to rub and that’s where my sound is coming from and I need to adjust but before I go chasing noises just wanted to see if anyone else has had this issue? Thanks!
  2. Feb 18, 2020 at 6:17 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    They're been posts about aftermarket rear rotors rubbing the dust shield for clearance. Take a look and see if you scrape marks.
  3. Feb 20, 2020 at 12:15 AM
    gears_call
    Orange County, CA
    2014 SR5
    So for anyone who reads this and has a similar issues I opted for powerstop front and rear rotors and pads. I took the above advice and checked the dust covers as I had seen posts about it. I massaged the metal back a little bit with a hammer and air hammer however still had the issue. My issue I ended up finding was the bracket that holds the piston was actually rubbing the surface of the rotor on the rear passenger side and binding enough that i couldn’t turn the hub/rotor by hand. I had the rotor turned ever so slightly by a shop down the street and the issue was resolved. Just a heads up for ideas if anyone ever comes across this post with a similar issue.
  4. Feb 20, 2020 at 4:01 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    That's pretty crappy fitment. I'd be mad.
    Never liked those Powerstop kits. Another reason for me not to buy them.
  5. Feb 20, 2020 at 4:11 AM
    gears_call
    Orange County, CA
    2014 SR5
    I wasn’t pleased. But didn’t find many reviews on the kits and took a chance. Get what ya pay for lesson learned
