3rd Gen "BMC" (Body Mount Chop) W/Relentless Fabrication BMC plates
Discussion in '2.5 Gen Tundras (2014-2021)' started by LittleTRD, Mar 6, 2020.
  1. Mar 6, 2020 at 3:30 PM
    LittleTRD
    LittleTRD [OP] New Member
    James
    Central California
    2015 Tundra Crewmax
    Camburg UCA's, Fox Factory 2.5's Front & Rear, Coachbuilder +3 Shackles, Decked Bed System, Snugtop Rebel Shell, switch pros 9100, and baja designs for all additional lighting.
    Hey all, figured i'd share my BMC on my 3rd Gen Tundra.
    2015 Tundra Crewmax
    Fox 2.5 Factory's
    Camburg UCA's (Balljoint version)
    35" x 12.5" x 18" BFG KO2's
    I was rubbing quite a bit after all suspension and tires were installed. I was looking in my immediate area (Central Valley, CA) for a shop to perform the BMC, but the finished results I was seeing from the customers:eek:, pushed me to give it a shot myself.
    So decided to hit up the staff at @RelentlessFabrication :thumbsup: and tackle the BMC. Check it out. Hope it helps other members out, if they were on the fence about doing one or taking it to a shop.
    Started by engaging parking brake and removing Terminals from Battery.
    Jacked up front end and put on jack stands to remove both front tires.
    Marked the body mount using the Relentless Fab plates.
    Cut using grinder w/ Cut off wheel.:sawzall:
    Test fit RF BMC Plate and used Flap Disk on grinder to take material off until I was satisfied with fitment.
    Once satisfied with fitment tacked the RF BMC plate in place.
    Proceeded with welding the plate. :welder:Did short stitches(welds) with Wet Rag around rubber bushing to prevent too much heat build up. Keep bucket of water close with an additional rag to dab on metal between welds for cooling.
    Stand back check out your work, drink a cold one:cheers:, then repeat all previous steps on passenger side......
    I chose this paint because it looked to match the factory Toyota chassis black pretty well. Plus it said Chassis on it. Lol:D
    And That's all folks. Took about 2.5-3hrs all together (jacking up the truck, layout, cutting, and welding) Not including painting time, Had to wait till the weekend since I had to drive to work the next morning and it was raining.
    Hope this helps, if I didn't cover something you want to know, shoot me a question.
    -LittleTRD
  2. Mar 6, 2020 at 4:44 PM
    mttjdy
    mttjdy New Member
    Awesome man! How’s your alignment been with the Camburg UCA?
    LittleTRD[OP] likes this.
  3. Mar 6, 2020 at 5:31 PM
    LittleTRD
    James
    Central California
    2015 Tundra Crewmax
    Thanks @mttjdy It's pretty good now. Definitely drives different than a stock truck. It doesn't self center as much as stock geometry.
    It did take two alignments to get it right though. I got lucky at my local Dealership, there was a tech familiar with Camburg components my second time around, and I've been requesting him ever since.
  4. Mar 6, 2020 at 5:56 PM
    mttjdy
    mttjdy New Member
    Good to hear. Is the whole camburg/alignment deal just that they are built for a lot more caster? I wonder if this applies to both their uniball and sealed ball joint styles.
    LittleTRD[QUOTED][OP] likes this.
  5. Mar 6, 2020 at 6:10 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Awesome job!
    I have my plates (been seeking shops), but after this post I'm more than confident to do this myself. Thanks for the detailed, step-by-step!
  6. Mar 6, 2020 at 7:18 PM
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    Damn wish I could weld....
  7. Mar 6, 2020 at 7:32 PM
    TheBeast The Beach
    very nice job !
  8. Mar 6, 2020 at 9:36 PM
    SnowB0und
    SnowB0und New Member
    2013 SR5
    Nice welds, TIG?
  9. Mar 6, 2020 at 9:57 PM
    LittleTRD
    James
    Central California
    2015 Tundra Crewmax
    Thanks @SnowB0und I ended up using a MIG to keep the the the heat down as much as possible.
  10. Mar 9, 2020 at 8:57 AM
    LittleTRD
    James
    Central California
    2015 Tundra Crewmax
    Ya @mttjdy, They are meant to be that way, I believe both models (uniball & balljoint) are built with the added caster.
    mttjdy[QUOTED] likes this.
  11. Mar 10, 2020 at 10:33 AM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Well done @LittleTRD , Thank you for sharing the step by step process.:cheers:
  12. Mar 10, 2020 at 10:45 AM
    LittleTRD
    James
    Central California
    2015 Tundra Crewmax
    Thanks @saybng :cheers:, I'm trying to contribute good info to the forum, since I got soo much good info for my build(still going....Lol) from here. Never joined a forum previously, so still learning how to do stuff on here.
    Luckydog and saybng like this.
  13. Mar 10, 2020 at 11:04 AM
    Warreng
    Warreng New Member
    Put a guard on your grinder.
  14. Mar 10, 2020 at 11:29 AM
    LittleTRD
    James
    Central California
    2015 Tundra Crewmax
    Thanks, @Warreng :thumbsup: Definitely. Its usually always on. I was actually a little scared the whole time I was cutting, because I took it off due to the speedycut wheel I bought being too large.:wink:
    pvn.beluga and Warreng like this.
  15. Mar 10, 2020 at 12:38 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    How much clearance did you get out of it? It doesn't seem like much, but I'm sure that's just deceiving. I'm going to be doing this soon since I have the plates from boss offroad already and need to do it since mine is running there since lift. Thanks for write up too....helps alot!
  16. Mar 10, 2020 at 12:51 PM
    Krautman73
    Krautman73 New Member
    Austin, Tx
    2018 SR5 Crewmax TSS
    6" Maxtrac suspension lift 20x10 KMC XD Buck 25s with -24 offset 35x12.5x20 BFG KO2s Cherry Bomb Extreme muffler 2/1 Stubby antenna
    Nice job bro, I'm about 3/4ths of the way there, just need to find a local shop to take care of the welding portion. What grit was the cut off wheel that you used?
  17. Mar 10, 2020 at 1:34 PM
    LittleTRD
    James
    Central California
    2015 Tundra Crewmax
    Thanks man, The cutoff wheel I used didn't have a grit rating but was 1mm thick and for cutting metal/stainless. The Flapdisk I used was 120grit, and then I had a Scotch Brite wheel I had laying around to make it nice and smooth.
    Krautman73[QUOTED] likes this.
  18. Mar 10, 2020 at 1:38 PM
    LittleTRD
    James
    Central California
    2015 Tundra Crewmax
    The clearance toward the inner wheel well doesn't change much, it gradually increases as you get to the farthest outside portion of the body mount. At the outside edge, I would estimate I gained about 1-1 1/2 inches. But, before the chop I could not reach full turn with the wheel either direction, Now I can reach the limit on both directions.
  19. Jul 13, 2020 at 6:39 PM
    Ebayollis
    Ebayollis New Member
    Josh
    Spruce pine NC
    2020 Voodoo limited
    Great job...I guess I'll order some and do it myself
  20. Jul 13, 2020 at 7:20 PM
    dgtulsaguy
    dgtulsaguy New Member
    18' 1794
    Great job and good welds! Plates look solid too. Thanks for the write-up, bookmarked for later
  21. Oct 30, 2020 at 8:39 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
  22. Oct 30, 2020 at 9:08 AM
    PeakIT
    PeakIT Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    Your welds look good. I’m thinking of upgrading my Miller to a 220 multiprocess. I want to mess around with Tig.
  23. Nov 9, 2020 at 5:45 AM
    Tundradrenalin
    Virginia Beach, VA
    Did mine this weekend. I went a little more aggressive with the grinder than you and cut more off. There really aren't any instructions out there besides good forum members like you who posts photos (thank you!) If you're thinking about doing this, bookmark this thread.
    Hardest part was getting the cuts similar on each side. Grinder wheel didn't fit very well in some places. My welds don't look as good as yours, but I flap disc'd them smooth anyways. From the outside it looks like I didn't do a thing! I did some test coupon welds and they all looked complete. Took about 90 minutes per side from jack to paint.
    pvn.beluga and LittleTRD[OP] like this.
  24. Nov 9, 2020 at 9:37 AM
    LittleTRD
    James
    Central California
    2015 Tundra Crewmax
    Thanks @Tundradrenalin glad it helped. Ya I know what you mean, mine are slightly different from side to side as well, its hard to reference a particular point on the two sides. But as you said, when complete and painted, you cant tell from outside anyway. Cheers man. :cheers:
  25. Jun 23, 2021 at 10:36 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Thinking about prepping my BMC and give it a go even though I've never welded. Going to pick up one of those HF flux welders!
    Just wondering though, will these be sufficient to cut through the body mount?
    and what about grinding the welds in after? what disc should I look for?
  26. Jun 23, 2021 at 11:03 AM
    LittleTRD
    James
    Central California
    2015 Tundra Crewmax
    Hey @pvn.beluga, That will be perfect for making the cuts. Mine was the 1mm thick cutoff.
    As far as grinding the welds after welding, I would use a 4.5" flap disc (80-120grit) instead of a grinding wheel. It will take slightly longer but the finished result will be much better.
    [​IMG][​IMG]
    pvn.beluga[QUOTED] likes this.
  27. Jun 23, 2021 at 11:04 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Nice! I was looking at this one earlier, but unsure. Definitely want that weld-in to be clean looking! Thanks!
  28. Jun 29, 2021 at 2:40 PM
    vudo2
    vudo2 New Member
    2018 Tundra Off-Road Limited / Cement
    Thank you for this post LittleTRD! This was right on target with what I was looking for so I immediately became a member of this forum! Your pics were excellent and even better than a few of the videos I watched on YouTube on how this mod is to be done.
    I just hope its as straight forward on my 2018 Tundra Off-Road Limited. I do know there will probably be some issues with getting my wheel-Well shroud moved out of the way on the 2018 to get full clearance to the mount and not sure how close the actual 2018 config is to the 2015 you have.
    I'd pay fair money for someone to do this as good as you did...the one local installer near me gave me some pretty bad vibes on their experience and level of attention to detail on this fabrication and almost all other shops I called have never done anything like this or simply said they won't do welding mods of this sort.
    Seemingly we have allot of poser 4x4 shops up near me who are in it for the green and not the actual pride and accuracy in the process :) Must be why none I could find actually know about this mod for the Tundra...but then again Ohio isn't known for its Off-Road enthusiasm.
    If anyone could refer to me to decent shop in Northeastern Ohio who would be a good recommendation for this mod I'd be very appreciative.
  29. Jun 29, 2021 at 2:43 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Come and do my truck, I need some 35’s.
    LittleTRD[OP] and vudo2 like this.
  30. Jan 14, 2022 at 4:50 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    2013 5.7 4WD CM Bench-Seat Silver
    6” Pro Comp 37’s Custom audio and interior Off road capability is current focus
    i learned this past year during the stay at home event.
    i bought a Lincoln from Home Depot and watched a couple YouTube videos.
    it’s surprisingly easier than other skills I have learned
