3rd Brake Light
Discussion in '2nd Gen Tundras (2007-2013)' started by rons23, Mar 1, 2016.
  1. Mar 1, 2016 at 5:47 PM
    rons23
    rons23 [OP] Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Anyone with a dc replaced there 3rd brake light? I posted about this but can't find it, and believe I didn't get a lot of response from that. I keep seeing you have to remove headliner, really don't want to do that, but if someone knows a easier way, I'm all ears. Thanks
  2. Mar 1, 2016 at 6:05 PM
    IIRC, the lens pops off.
  3. Mar 1, 2016 at 6:07 PM
    rons23
    Ron
    Kill Devil Hills
    Sorry not great with acronyms,
  4. Mar 1, 2016 at 6:14 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    If I remember correctly. Yes the lens comes off.
    T-Rex266 likes this.
  5. Mar 1, 2016 at 6:17 PM
    rons23
    Ron
    Kill Devil Hills
    I'm not wanting to just change bulbs, I'm switching out the whole assembly, which requires that you atleast pull down the headliner to get to the 2 10mm nuts. Seems like more trouble than it's worth.
    Black Wolf likes this.
  6. Mar 1, 2016 at 6:19 PM
    Virgils12
    How come you wanna change it??
  7. Mar 1, 2016 at 6:25 PM
    rons23
    Ron
    Kill Devil Hills
    Just going with the black_out theme. Was hoping someone else had done it. There's the potential for water leak to, so looking more like its not gonna happen. Thanks for chiming in
  8. Mar 1, 2016 at 6:28 PM
    Virgils12
    So you don't want it at all? Or you want to just tint the lens? Pull the lens and do the vht night shades mod? Just not sure what you are wanting to do.
  9. Mar 1, 2016 at 6:35 PM
    rons23
    Ron
    Kill Devil Hills
    I found a black led 3rd brake light on eBay, was going to swap my factory assembly out. Night shades are an option also. Here's the lightuploadfromtaptalk1456886146916.jpg
  10. Mar 1, 2016 at 6:41 PM
    Virgils12
    Now I see. I like that. So do you have or would you add tail lights that kind of match? If no I would say the night shades of that light and your tails would look better do they matched. If you do the tails that have the small LEDs I would go for it!
  11. Mar 1, 2016 at 6:44 PM
    rons23
    Ron
    Kill Devil Hills
    Yeah I got black Spyder leds for my tails, so yes this would look good. I'm just leary about messing with the headliner. Got a couple of mechanic buddies, I might just get it installed. Thanks for your help Virgils 12
  12. Mar 1, 2016 at 6:48 PM
    Virgils12
    Awesome! I think it will look good. Take your time and watch the YouTube's for pointers.
    rons23[OP] likes this.
  13. Mar 1, 2016 at 6:48 PM
    Definitely looks very cool. I've seen some decent tinted lens. How about tinted lens with LED upgrade? I'f you ever get a topper or camper you won't see it anyways. Definitely looks real cool.
  14. Mar 1, 2016 at 6:53 PM
    rons23
    Ron
    Kill Devil Hills
    These are clear with black housing, just wanting brighter brake light and this one comes with leds in it.
  15. Mar 2, 2016 at 6:25 AM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    I remember this. I think I pulled some Chilton manuals for this.
  16. Mar 2, 2016 at 6:27 AM
    Nor7
    And for the installation.
  17. Mar 2, 2016 at 6:28 AM
    Nor7
  18. Mar 2, 2016 at 8:28 AM
    Nor7
    No problem at all. For future reference, I started a thread 'Ask the Chilton Manual Guy'. And it's not limited to just Tundras so if you've got a project car sitting in your garage feel free to ask away.
    rons23[OP] and NewImprovedRon like this.
  19. Mar 2, 2016 at 12:22 PM
    alalmcgrath
    alalmcgrath Old Fart at Large!
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    There is a YouTube video by HEADLIGHT REVOLUTION on how to do this.
  20. Mar 2, 2016 at 12:27 PM
    Virgils12
    Everything is on the youtube's
  21. Mar 2, 2016 at 12:46 PM
    alalmcgrath
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    I know, ain't it great? I use it for all my Tundra questions.
  22. Mar 2, 2016 at 3:03 PM
    rons23
    Ron
    Kill Devil Hills
  23. Mar 2, 2016 at 5:21 PM
    Cutter29
    Cutter29 ...
    Utah
    2015 Super White TRD PRO
    Just pull the lens off and tint it. I picked up a spare OEM lens cheap online and just had it sprayed along with my tails. Takes 5 minutes to swap and you can replace the bulbs while you're at it. Super easy unless you want a different bulb pattern inside
  24. Mar 2, 2016 at 5:28 PM
    rons23
    Ron
    Kill Devil Hills
    Thanks Cutter29, I watched the video @headlight revolution and it doesn't look to hard to pull headliner down. I was told though if I wanted to just change out bulbs to leds that I would still have to pull down headliner. With that said I will install aftermarket assembly. The 3rd generation is much easier
  25. Mar 2, 2016 at 5:40 PM
    Cutter29
    Cutter29 ...
    Utah
    I missed the second gen part. :facepalm:My bad. I wondered why you were trying to make it difficult.
  26. Mar 2, 2016 at 5:44 PM
    rons23
    Ron
    Kill Devil Hills
    Yeah, I was just gonna bag it and just swap out factory bulbs with leds, but noooo, so it's installation time.
    Cutter29[QUOTED] likes this.
  27. Mar 2, 2016 at 11:54 PM
    alalmcgrath
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    I changed out mine to LED'S by just removing the lens, piece of cake.
  28. Mar 3, 2016 at 12:32 AM
    rons23
    Ron
    Kill Devil Hills
    Is your Tundra a 3rd generation?
  29. Mar 3, 2016 at 2:39 AM
    bigsapz
    bigsapz New Member
    Beast
    I too was going to swap out the 3rd brake light with a tinted led one but after seeing what's required, I said F that, way more hassle than its worth. Ended up swapping out oem bulbs with LEDs and tinting the lens with night shades to match my Spyder tinted taillights. f286a33f13ae96ef7c45f22ae103eaab_7f34023d9b8984a245e1ca2bf44c1a2f1092041b.jpgec05e17d56d807c1608963e60f732777_e2e1cc9b3e08ce303211a1568ba8f7c62daf3167.jpg
  30. Mar 3, 2016 at 4:58 AM
    bigsapz
    bigsapz New Member
    Beast
    One with the lights on at night 561aafb08065ed84a5b28acae20df1bf_f5c3693c6489fdf957ee3c681861b0c0b0c2aaf7.jpg
