3rd Brake Light Woes
Discussion in '2.5 Gen Tundras (2014-2021)' started by undermyvoodoo82, Feb 20, 2019.
  1. Feb 20, 2019 at 3:08 PM
    undermyvoodoo82
    undermyvoodoo82 [OP] New Member
    '19 Crewmax Limited TRD
    So thought it would be a great idea to swap some of the lights on my truck for LEDs and in the middle of changing the cargo lights in the 3rd brake light housing I fumbled a standard bulb into the hole just below fixture and into the void brake light housing sits in. After trying to fish it out I effectively flipped it further into the passenger side of the cab. Is there a effective way to retrieve the lost bulb or am I just S.O.L? Any help would be greatly appreciated.
  2. Feb 20, 2019 at 3:15 PM
    15whtrd
    15whtrd Mr. Blonde
    Try a magnet with a telescope feature. Also Ron’s idea is good too.
  3. Feb 20, 2019 at 3:20 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Or fishtape wire like a bike brake line, double sided foam tape... whatever you can McGyver with existing supplies.
    15whtrd likes this.
  4. Feb 20, 2019 at 3:21 PM
    undermyvoodoo82
    Due to the angle and the size of the hole whatever I stick in has to be flexible. I tried zipties and even tried jerry rigging some hose to my shop vac with no luck.
  5. Feb 20, 2019 at 3:27 PM
    undermyvoodoo82
    Does anybody know if it's accessible by dropping the headliner?
  6. Feb 20, 2019 at 3:30 PM
    15whtrd
    15whtrd Mr. Blonde
    I’ve heard that’s quite the task.
  7. Feb 20, 2019 at 3:38 PM
    TundraCoast
    TundraCoast Member In Good Standing
    Ian
    California
    1794 4x4
    1794 on the inside - PRO on the outside
    OR18TRD, NewImprovedRon and 15whtrd like this.
  8. Feb 20, 2019 at 3:40 PM
    TundraCoast
    Ian
    California
    1794 4x4
    Dropping the headliner is a huge PITA, I wouldn't recommend going that route.
  9. Feb 20, 2019 at 3:50 PM
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    How about using a vacuum?
    I have taken a vacuum hose attachment and reduced it down to a 1/2 hose from a hand pump I have which is flexible which you can fish in the cavity and the suction drew the part in like a magnet
  10. Feb 20, 2019 at 3:51 PM
    undermyvoodoo82
    Went in that hole and I literally had finger on it for 15-20 minutes trying to fish it back and forth before it got flicked further into the passenger side.
  11. Feb 20, 2019 at 4:00 PM
    waynescaggs
    waynescaggs No more of that .
    Wayne
    Idaho
    2019 tundra Crewmax Limited
    What will happen if you leave it there?
  12. Feb 20, 2019 at 4:16 PM
    Firefly412
    Firefly412 New Member
    Robert
    2018 SR5 Double Cab
    Go by your local airport and ask for the A&P mechanic. They might have a flexible LED borescope that they will help you fish out the bulb. If they don’t have one, they might know a pilot on the field that does. Some of them have magnets on the end, or you might have to be creative. At least you can see where it is.
  13. Feb 20, 2019 at 4:35 PM
    TundraCoast
    Ian
    California
    1794 4x4
    There is a cavity or sub-shell around the 3rd brake light housing, I've had the headliner partially down on 2 Tundras to install aftermarket 3rd brake lights (huge pain) and I have dropped the securing nuts twice its a tight space for hands and tools. I have been lucky both times and fished out the nuts with a flexible magnet tool. If you have driven the truck since the bulb fell back in there its possible that its has gone into the void
  14. Feb 20, 2019 at 4:37 PM
    War Machine
    War Machine SSEM # 5 3MW
    If I recall from previous posts, taking the light out requires taking the headliner loose.
  15. Feb 20, 2019 at 5:32 PM
    undermyvoodoo82
    @TundraCoast yeah it's in that subshell area, and unfortunately I had to drive it and if took the corners hard enough I could hear it bounce/slide around. Maybe I'll get lucky and it's back a little more center now but that's wishful thinking. At least the replacement lights look good:anonymous:
  16. Feb 20, 2019 at 5:45 PM
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    We dropped my headliner to install the 3rd brake light. It is a pain but certainly doable. Took out seats.
  17. Feb 20, 2019 at 7:25 PM
    15whtrd
    15whtrd Mr. Blonde
    I have a rigid brand flexible borescope from Home Depot. It has a magnet attachment. I wish I could help you.
  18. Feb 20, 2019 at 9:06 PM
    muisejt
    muisejt New Member
    2017 Sunset Bronze 1794 Edition 4x4
    Auburn LSD, TRD rear sway bar, LED interior lights, Weathertech floormats, Fumoto valve
    if it happened to me I would just leave it, not going to hurt anything. my time is money and I'm not going to "spend" $100 to retrieve a $1 light bulb. I have a bag full if bulbs in my garage collecting dust from when I put LEDs in my truck, probably never be used again
  19. Feb 21, 2019 at 4:32 AM
    undermyvoodoo82
    @15whtrd thanks for the idea, I didn't realize borescopes were priced at what they are. Amazon has some options that hook directly to a phone or laptop may be worthwhile for some other projects around the house.
  20. Feb 21, 2019 at 6:48 AM
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
    I would not worry about it personally if you have tried this many times and cannot figure it out. It would bug the crap out of me too, I get it, but it will eventually find a happy home up in there at some point. Maybe a Toyota garage has had this happen and has a fix for fishing the bulb out.
  21. Feb 21, 2019 at 7:08 AM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
    SmartSelect_20190221-101238_Amazon Shopping.jpg there are aluminum flex handle magnets that can be bent in many ways. I use one for retrieving dropped hardware. your only challenge is if the bulb dies not have a ferrous body for the magnet to work.
    15whtrd and NewImprovedRon like this.
  22. Feb 21, 2019 at 12:50 PM
    undermyvoodoo82
    Ordered a 36in "magic" claw and a cheapy wifi borescope with some attachements to hook up to my phone and see if I can't fish it out, hopefully I can get sometime in the next few days to fish around.
    NewImprovedRon likes this.
  23. Feb 21, 2019 at 8:57 PM
    undermyvoodoo82
  24. Feb 22, 2019 at 3:45 AM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    just a tip... make sure you tape the attachments down before attempting a rescue. sometimes they snag and pop off specially if the magnet grabs something that does move.
  25. Feb 22, 2019 at 5:38 AM
    undermyvoodoo82
    @ardnutoz that was one of my concerns when looking at all the borescopes that were available. The extra tips that are included are threaded and I was confident the magnetic tip was on securely before I fished it back down. I heard/saw it doing magnet things on the way back down so it should definitely be a concern for anybody that has a tip that slips on or pops over the camera especially with it being open like a hook on the way back out, there are plenty of small rivets, braces and holes in that area that can catch if you aren't careful.
