3rd brake light moisture
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bradyu123, Jun 11, 2021.
  1. Jun 11, 2021 at 2:03 PM
    Bradyu123
    Bradyu123 [OP] New Member
    Brady
    2021 White Tundra double cab
    stock
    Just purchased a 2021 trd tundra and was wondering if water/condesation was normal inside the third brake light around outter edge red portion? Dont see any moisture inside where the bulbs sit.
  2. Jun 11, 2021 at 2:10 PM
    A very small few have discovered that the gasket was missing. The gasket is light gray and is around the bulb housing area. I would remove the lens, dry everything out and put it back together and see what happens. Maybe the screws are loose. Just don't crank down on them and crack the plastic.
  3. Jun 11, 2021 at 2:11 PM
    TexAggie
    TexAggie New Member
    Eric
    2017 CM
    Hard to see exactly on photo, but you can easily unscrew cover remove and check seal.
  4. Jun 11, 2021 at 3:41 PM
    Bradyu123
    Brady
    stock
    Took it apart changed cargo light bulbs to leds and dried lens. Gasket looks to be in place and in good shape put it back together will keep an eye on it thanks you
    Tundra234[QUOTED] likes this.
  5. Jun 11, 2021 at 3:41 PM
    Bradyu123
    Brady
    stock
    seal looks good tightened back up will keep an eye on it
    TexAggie[QUOTED] likes this.
  6. Jun 12, 2021 at 1:37 PM
    34ford
    34ford New Member
    2018 sky silver DC 5300 miles
    none yet
    Maybe a little silicone GREASE not sealer on gasket will help seal and slow down UV light damage to gasket. 34ford
