3D scanning and 3D printing
Discussion in 'Sports, Hobbies & Interests' started by BeardedTundra, Mar 11, 2025.
  1. Mar 11, 2025 at 6:27 PM
    BeardedTundra
    BeardedTundra [OP] Shr3k
    Justin
    2006 Sequoia Limited 4x4
    Big mods are coming soon, but not too soon.
    Does anyone here 3D scan and 3D print?
  2. Mar 12, 2025 at 7:13 AM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    2020 Tundra Limited on 35's
    I have done both, did you have a question?
    BeardedTundra[OP] likes this.
  3. Mar 14, 2025 at 10:34 PM
    DirkS
    DirkS New Member
    Dirk
    Abbotsford, BC
    2016 Tundra Limited
    Yep -just starting getting into 3d printing.
  4. Mar 15, 2025 at 6:06 AM
    BeardedTundra
    Justin
    I am interested in building a sunroof bracket for a 1st gen Sequoia that will house a fantastic fan for car camping. I see how accurate and efficient 3D scanning is and I think it could be 3D built.
  5. Mar 17, 2025 at 7:02 AM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    You wouldn't necessarily need a 3D scanner for something like this. But I don't know of a 3D printer that can print that large. IF there is one out there that is capable of that size of a print it would not be cost effective at all. Likely $1000's of dollars.
  6. Mar 17, 2025 at 7:27 AM
    DirkS
    DirkS New Member
    Dirk
    Abbotsford, BC
    2016 Tundra Limited
    Many large “home” 3d prints are comprised of smaller pieces glued together - that could be an option. It would take some planning and work though.
  7. Mar 17, 2025 at 7:55 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I have both. For something like that I'd just draw it up and cut it out manually on some metal and have it clamp onto the sunroof housing. Unless you're very experienced with CAD it will be a process to work with the scan, and the geometry you need isnt that complicated. You could certainly 3D print it, but again that needs some CAD expertise and at the end of the day won't be that much different than fabricating something and probably take longer.
    Maybe a good question is what skills do you have and tools do you have access to already :D
